| Author |
Message |
AshCampbell Ryousuke
Posted: Sun Apr 15, 2007 6:10 pm Post subject: Drifting with stock power on the dry |
HI!
I was a bit "drifting" today, now with the kaaz 2 way lsd i got much more grip on the dry, i have 195 tyres on 15 inch wheels with koni suspension on the car. its very tricky to get the hachi roku sideways, i am not using e-brake technique i dont like that....
_________________
DRIFT THAT SHIT!
| Back to top |
Bean Bandit Takumi
Joined: 23 Jul 2006 Posts: 208 Location: Zurich/Switzerland
Posted: Sun Apr 15, 2007 6:30 pm Post subject: |
use shittier tires, more revs and increase pressure in the reartires to ~40psi or more
one or all of the above should do the trick
_________________
| Back to top |
| Back to top |
Denmark Takumi
Joined: 16 Oct 2004 Posts: 290 Location: Norup,Denmark
Posted: Sun Apr 15, 2007 6:39 pm Post subject: |
I had the same probelm in the beginning, and also thought that i had to much grip,but its simple becource you are going to slow!,
And that is not my trying to say anything about your driving,
But that was the same with me,
With the hachi, you need to go fast ,at the entry,
it´s alot easy´er when you get more power,then you can drift at a lower speed,
but it´s also much more fun to do it faster, becourse there is not much power over drift anyway,
So drift from the entry of the corner
/Skassa
_________________ Any fool can go fast in a straight line.
"""www.turbotoys.dk"""
| Back to top |
Posted: Sun Apr 15, 2007 7:08 pm Post subject: |
I come to this corner in third gear, maybe 100-110km/h then i brake late, still in third gear, steer in and shift down to second without toe and heel, then the rear brakes out...
_________________
DRIFT THAT SHIT!
| Back to top |
kid Ryousuke
Posted: Sun Apr 15, 2007 8:18 pm Post subject: |
get the Camber done Ash... we talked about it already... you will be having more fun... especially with the KAAZ pusching so much your front end needs to have more grip!!!
_________________
| Back to top |
Posted: Sun Apr 15, 2007 8:27 pm Post subject: |
yeah bro i know, my front tyres smoke more then my rear ones do
_________________
DRIFT THAT SHIT!
| Back to top |
kid Ryousuke
Posted: Sun Apr 15, 2007 10:21 pm Post subject: |
it should be the other way around!!! or are you driving a AUDI?
no for real... camberplates... about 1.8 of camber and your Konis set to 3/4 front and 3,5/4 rear... you will have nice balance and no more understeer!! I had the same Setup with the Kaaz 2 way before... that was a nice setup...
now I will run Greddy Type S + Cusco RS LSD... I think i will feel the difference!!!
_________________
| Back to top |
Posted: Mon Apr 16, 2007 10:19 am Post subject: |
why did you change your lsd?
_________________
DRIFT THAT SHIT!
| Back to top |
kid Ryousuke
Posted: Mon Apr 16, 2007 12:54 pm Post subject: |
the Kaaz didn't make the effect I wanted... the Cusco RS works with lower torghe because of the spring layout... the Kaaz works with the disc layout... Kaaz is good... but Cusco RS is the something else
_________________
| Back to top |
mrgud Takumi
Posted: Mon Apr 16, 2007 4:13 pm Post subject: |
hehe, that is why I use 13'' wheels (because I don't have any but those )
_________________ SNO-MO-BIRU project started- CHIRO
| Back to top |
Mux213 Site Admin
Posted: Mon Apr 16, 2007 4:28 pm Post subject: |
Just out of interest,
Does any of you guys remember this guy called Zax that sometimes posts on this forum?
8Kg front, 6Kg rear springs, shortstroke KONI shocks, a modified double rear strut bar and a dying 4AG in the front.
Stock LSD
Stock engine, if it was still doing 110Hp it would have been a miracle
Sideways 24x7 at Mobikrog, snow, ice, dry, wet, it didn't matter. www.go-drift.com
Damn I miss that white hachi of his....
_________________ Greetz,
No more hachi
| Back to top |
| Back to top |
kid Ryousuke
Posted: Mon Apr 16, 2007 11:14 pm Post subject: |
just looked at your video.. nice job..
but i see that your car is a little bit soft.. in German: Schwammig....
maybee some Buschings and a Tanabe Stabilizer set yould do good work...
With the camber you could get it drifting befor the turn starts.. so it wouldn't
be a power over drift...
_________________
| Back to top |
DJexor Moderator
Joined: 24 Oct 2004 Posts: 1405 Location: Netherlands, Den Haag
Posted: Mon Apr 16, 2007 11:28 pm Post subject: |
nice drifting!
_________________
AE86 Levin 2drs
| Back to top |
Posted: Tue Apr 17, 2007 12:06 am Post subject: |
bushing kit will come this winter, stabilizer from whiteline i think will do their job well
_________________
DRIFT THAT SHIT!
| Back to top |
kid Ryousuke
Posted: Tue Apr 17, 2007 9:31 am Post subject: |
not shure about the whiteline stabilizers... Studebaker from München has them and he is not satisfide... He even thought the OEM ones were better... but maybe he has a different driving style then you do...
_________________
| Back to top |
robokill Bunta
Joined: 07 Sep 2004 Posts: 2105 Location: Amsterdam // The Netherlands
Posted: Tue Apr 17, 2007 10:58 am Post subject: |
ash hearing the revs in your car you are not near 6600 ? Drifting a stock hachi mostly takes it upto 7000 rpm and alot trying. But first I would recommend a difrent learning spot. This corner is pretty long and your speed at entry must be much higher.
Its not safe to learn drifting on these long corners. Try a parkinglot or a small corner. Start in first gear 90 degree turn before you try these long ones. You might hurt yourselve
_________________ "05 Ford Mondeo Daily moving object
KIS it
Keep It Sideways
| Back to top |
Mux213 Site Admin
Posted: Thu Apr 19, 2007 10:40 am Post subject: |
Ash,
Watch this vid: http://www.go-drift.com/video/go-drift.com_9V.wmv
Skip the first minute or so, thats just parking lot fun, the real stuff starts after that.
there is also a topic somewhere from HRC with a vid of him on this same track, also with a near stock hachi with only upgraded suspension.
No more hachi
| Back to top |
NoHachi Moderator
Joined: 07 Sep 2004 Posts: 1998 Location: Delft - The Netherlands
Posted: Thu Apr 19, 2007 12:16 pm Post subject: |
Seems like his throttle is stuck in the open position
_________________ A wheel to steer the front of the car
Scuderia Rollator
| Back to top |
Posted: Thu Apr 19, 2007 12:38 pm Post subject: |
Oh boy, he´s revving that engine like hell, but i like it
_________________
DRIFT THAT SHIT!
| Back to top |
Mux213 Site Admin
Posted: Thu Apr 19, 2007 8:36 pm Post subject: |
| NoHachi wrote: | Seems like his throttle is stuck in the open position  |
I wonder if that car still has a throttle, it's probably been removed, just one big gaping air hole sucking in power:)
No more hachi
| Back to top |
Posted: Thu Apr 19, 2007 9:17 pm Post subject: |
how long will this engine last?
_________________
DRIFT THAT SHIT!
| Back to top |
Mux213 Site Admin
Posted: Thu Apr 19, 2007 9:50 pm Post subject: |
| AshCampbell wrote: | how long will this engine last?  |
The reason the white hachi no longer rides, is due to a blown engine:(
No more hachi
| Back to top |
matt mead Ryousuke
Joined: 01 Jun 2006 Posts: 156 Location: Sydney, AUSTRALIA
1984 Toyota Corolla AE86 (early JDM Levin)
Posted: Thu Apr 19, 2007 11:04 pm Post subject: |
if u wanna drift, get 6kgrear springs, set dampers to full hard, weld another swaybar on.... then go have some fun
| Back to top |
