| Author |
Message |
adomz Bunta
Joined: 24 Mar 2005 Posts: 808 Location: Ilford, London, UK
1983 Toyota Corolla AE86 (early Levin)
Posted: Tue Apr 04, 2006 9:51 pm Post subject: some mad lock angle he's got! |
damn!
_________________
| Back to top |
Jezza_hr Bunta
Posted: Tue Apr 04, 2006 9:56 pm Post subject: |
I've seen those kind of angles before. To see it actually in motion is just amazing
| Back to top |
banpei Site Admin
1982 Toyota Carina
Posted: Tue Apr 04, 2006 10:13 pm Post subject: |
How many turns would that be from lock to lock?
| Back to top |
nmwisima Bunta
Joined: 23 Dec 2004 Posts: 3771 Location: Athens Greece
1996 Mazda MX-5
Posted: Tue Apr 04, 2006 11:34 pm Post subject: |
Naaaaa, its just broken
_________________
| Back to top |
Knudsen Moderator
Posted: Wed Apr 05, 2006 12:34 am Post subject: |
Thats not that much different from stock, is it?
_________________ Youtube Myspace and I´ll Google your Yahoo
| Back to top |
dAYTONA Takumi
Posted: Wed Apr 05, 2006 3:34 am Post subject: |
He probably has the steering kit from battelversion...
I will soon install mine too... well not battelversion, but Doktorversion
Does the same thing, but twice as cheap
_________________
Koukis - Red, Silver/Gray,
| Back to top |
Mux213 Site Admin
Posted: Wed Apr 05, 2006 8:44 am Post subject: |
daytona, care to elaborate?
_________________ Greetz,
No more hachi
| Back to top |
Widar Bunta
Joined: 07 Sep 2004 Posts: 1820 Location: Borås, Sweden
Posted: Wed Apr 05, 2006 9:01 am Post subject: |
i'm with mux on this. Tell us more!
And don't forget the pictures!
_________________
| Back to top |
ZaX Moderator
Joined: 20 Sep 2004 Posts: 1440 Location: Croatia / Zagreb
Posted: Wed Apr 05, 2006 9:39 am Post subject: |
| Mux213 wrote: | daytona, care to elaborate? |
Maybe you should check "the topic".
I instaled this mod before winter on my ae86.
Also have it on my s13, but from Tein.
_________________ Go-Drift.com
| Back to top |
dAYTONA Takumi
Posted: Wed Apr 05, 2006 7:08 pm Post subject: |
Mux, Widar check out this topic
http://www.aeu86.org/viewtopic.php?t=2711&highlight=
they cost 45 euros. It's like the Battel Version kit 2.
To get about 8 degrees more angle, you just add some specially made washers.
To add a lot more angle, you need the second kit (45 euros) which can be seen on the first picture of the topic I have provided.
_________________
| Back to top |
D-Lish
Posted: Sun Apr 09, 2006 5:45 am Post subject: |
I still have not seen anyone outside of D1 with an extreme angle as in the photo. Ken Maeda, Ueo and a few others acheive the amazing. Is the spacer the best we can do?
_________________
| Back to top |
Ivan141 Moderator
Joined: 06 Sep 2004 Posts: 4853 Location: Netherlands Z-H
Posted: Sun Apr 09, 2006 10:49 am Post subject: |
I think those D1 guys probably use different steering racks with more travel.
I've read something about the TE71 rack having more steering travel than the ae86 for example.
'81 poor guy with a money-pit
| Back to top |
sultennok Ryousuke
| Back to top |
TE71corolla Bunta
Joined: 20 Jan 2005 Posts: 807 Location: nederland/purmerend
Posted: Sun Apr 09, 2006 5:39 pm Post subject: |
| Ivan141 wrote: | I think those D1 guys probably use different steering racks with more travel.
I've read something about the TE71 rack having more steering travel than the ae86 for example. |
_________________
| Back to top |
PazzaAE86 Ryousuke
Posted: Sun May 14, 2006 4:04 pm Post subject: |
Ok guys here is one way to get maximum lock... I mean, the lock in that picture is just stupid and im not sure you couldnt ever really use that much. I know for certain he spun after that cus i have the video but here is a way to get stupid lock..
Firstly, get Battle Version Spacer Kit #2. You'll find that this gives a huuuge amount of lock and unless you have really low offset wheels, the tyre will hit the chassis rail when you get near full lock.. For example my friend Jay has 14x7 0 offset wheels with 25mm spacers and it juuust about clears the chassis but has rubbed all the paint off. But using just the kit alone you'll be very happy.. But here is how to get more:
Secondly, if you couple the steering knuckles from a Power Steering AE86 with a Manual steering rack, this also gives a few more degree's lock and if you coupled this with the BV Kit #2 you will have huge problems with your wheels hitting the chassis rail. The reason this works is because the Power steering knuckles are shorter in length that Manual ones.
There is a way to get round it and thats a combination of low offset wheels and adjustable lower arms and pillow ball upper mounts. This way you can pull the top and bottom of the suspension further out and it'll give you more clearence for the wheel to turn. Ueo Style are a great adjustable bottom arm but so expensive
Btw, either of those methods will work on their own and arent dependant on each other, its just thats how i believe you can get maximum lock possible on an 86. The amount you get is just silly!
_________________ Driftworks - JSPFab.com - DangerStyle - NightSpirit
| Back to top |
ZaX Moderator
Posted: Mon May 15, 2006 9:13 am Post subject: |
That's one very good post. Maybe we should make how-to or sticky?
Since I used shims on my s13 I installed them on my ae86, then Kas followed, Hrc and now dodo.
We are all very happy with this modification, no more problems with parking.
| Back to top |
adomz Bunta
Posted: Mon May 15, 2006 6:19 pm Post subject: |
haha...i already love the stock radius of rotation in my hachi, cause it has no CV joints in the front...LoL...
_________________
| Back to top |
mrgud Takumi
Posted: Sun Oct 01, 2006 5:27 pm Post subject: |
can somebody explain the working principle of this modification... I understand that with a spacer added it can move the wheel more out, but what is the point if you still leave the adjusment of the toe-in out the same... you adjust the tor-in-out, and when you steer you again have the same steering ratio... I didn't quite got the whole idea... I am looking to the manual right now and still can understand...
Can somebody explain this...
EDIT
Almost got it!!! Hopefully at the end of the day I will be able to explain it to myself, and later on to all of you GEEK LOL
(the speed of the steering changes (the trayectori of the wheel changes) because the tie rod has a difrent angle at the begining of it's travel)...
_________________ SNO-MO-BIRU project started- CHIRO
| Back to top |
assassin10000 Ryousuke
Joined: 31 Aug 2006 Posts: 131 Location: Sacramento, CA
Posted: Sat Oct 21, 2006 1:09 am Post subject: |
Basically - all your doing is giving the steering rack more movement left and right.
When coupled with unchanged suspension geometry it increases angle by allowing you to turn/move the steering knuckle further than before. Which means your wheels turn further = increase tire angle/smaller turning radius.
Further gains/losses/clearances can be had by changing other items such as the lower control arms, steering knuckles and wheel offsets.
Andrew
_________________ 1984 AE86 SR-5 (GT-S Converted)
1995.5 Toyota Tacoma 4x4 (Hilux)
| Back to top |
PazzaAE86 Ryousuke
| Back to top |
Posted: Mon Oct 30, 2006 6:51 pm Post subject: |
| PazzaAE86 wrote: | http://www.aeu86.org/viewtopic.php?t=3439&highlight=magic+tuning
I thank you. |
Hey pazza, did you have any issues with the p/s knuckles, bv#2 kit going overangle on the steering knuckles?
Basically going past the point of 'no' return and locking the steering?
When I was last underneath my car I found with stock ctl arms, p/s knuckles and manual rack (no spacers) that my steering knuckle/outer tie rod almost comes into contact with the ctl arm. Any more angle and I'd have to drop the front end to so it'll swing over the control arm.
With the #2 kit, p/s knuckles & manual rack I'm wondering if it would swing so far over you wouldn't be able to get the wheel to return easily, getting the front stuck at super lock and spinning you out.
Andrew
| Back to top |
pedro-siR Ryousuke
Joined: 11 Jan 2007 Posts: 137 Location: El Salvador, Central America
Posted: Fri Jan 19, 2007 4:27 am Post subject: |
i have a power steering car with BV#2, and the steering angle is just freacking unbelivable. I love to U turn where I wasn't able to before, or just parking.
_________________ Pedro Velado
GT-S Owner
| Back to top |
mrgud Takumi
Posted: Fri Jan 19, 2007 1:50 pm Post subject: |
What did we forgot here? bump and rebound- steer
| Back to top |
Plex Takumi
Joined: 30 Oct 2004 Posts: 239 Location: US Air Force, CA. USA
Posted: Sun Jan 28, 2007 8:23 am Post subject: |
Alot of pros also 'notch' out their frame where the wheel hits it... and reweld a new piece to it about an inch further in... if you know what i'm saying?
_________________ "Sometimes giving up isn't the answer we're looking for, but its the only answer we have"
| Back to top |
dr.occa Wataru
1986 Toyota Corolla AE86 (late US)
Posted: Sat Feb 17, 2007 9:07 am Post subject: |
| assassin10000 wrote: | ...I'd have to drop the front end to so it'll swing over the control arm.
Andrew |
i know this is somewhat of an old thread but...what he said.
oh, and hey by-the-way fellow club4ag-er assassin10000. we've crossed paths at least once on the forums.
_________________
| Back to top |
