| Author |
Message |
parrot Takumi
Joined: 24 Nov 2006 Posts: 279 Location: Melbourne AUSTRALIA
Posted: Fri Jan 12, 2007 2:12 am Post subject: Factory Electrical wiring diagrams & engine diagnosis ma |
I have scanned up the AE86 factory detailed Electrical Wiring Diagrams Book (1983) as well as the factory 4AGE TCCS Diagnosis Manual. Both have been my bibles for the last few years. Very useful.
Both are on this site in PDF
see below, now on aeu86.org server
The EWD is very detailed and contains each seperate circuit and illustrates each plug and where each wire goes within it. Not just the basic schematic diagrams, though they are there too. Engine diagnosis manual takes you through step by step for ECU and wiring related faults. Includes pinouts. This applies to AA and AE body series with 4AGE
Edit:
AE86 Wiring Diagrams EU/AU (1983) by Parrot (5Mb):
AE86 Wiring Diagrams (EU/AU)
AE86 Wiring Diagrams USDM (1986) by Parrot (5Mb):
AE86 Wiring Diagrams (USDM)
4A-GE Diagnostics Manual by Parrot (8Mb):
| Back to top |
pedro-siR Ryousuke
Joined: 11 Jan 2007 Posts: 137 Location: El Salvador, Central America
Posted: Fri Jan 12, 2007 2:39 am Post subject: |
it has tons of info. too bad it doesn't have the electric window diagrams because is for 1983...
those i needed
_________________ Pedro Velado
GT-S Owner
| Back to top |
parrot Takumi
Posted: Fri Jan 12, 2007 2:47 am Post subject: |
No problem, I have those too, BUT for the USDM model. The US looms are very different from the Euro looms however I expect the power window section would not vary much until it gets to the junction box. Though actually I note you are in Central America which I presume have LHD US spec GTS's.
I do not have this electronically and it was difficult enough getting access to a scanner to do these two files.
If you PM me either a fax number or an address I can send them to you on Sunday morning Australian time
| Back to top |
banpei Site Admin
1982 Toyota Carina
Posted: Fri Jan 12, 2007 6:22 pm Post subject: |
Parrot: Is it okay if we mirror the diagrams?
| Back to top |
pedro-siR Ryousuke
Posted: Fri Jan 12, 2007 7:15 pm Post subject: |
Yes parrot, i drive a USDM LHD corolla.
Please mail the diagrams to pedrovelado@navegante.com.sv . Thank you so much, I really appreciate it since I'm having problems with my passenger side window, I cannot open it, unless i take off the door panel and do it manually
GT-S Owner
| Back to top |
parrot Takumi
Posted: Sat Jan 13, 2007 8:35 am Post subject: |
Banpei - absolutely. I shall try and put up the USDM EWD and other assorted useful things at some stage. Scanning is not so easy unfortunately but I am working on a way around that.
Pedro - if you want it emailed you may have to wait a while as it isn't scanned. I shall see how I go. I can post or fax though.
| Back to top |
banpei Site Admin
1982 Toyota Carina
| Back to top |
parrot Takumi
Posted: Sun Jan 14, 2007 1:10 am Post subject: |
I'm famous!! Thanks Banpei.
Have just finished copying the USDM EWD too. It has all sorts of odd things such as the trueno pop up light circuit, cruise control, power mirrors, power windows etc.
I shall try and get this scanned on Tuesday and advise when it is up.
| Back to top |
SutteR Takumi
Joined: 19 Mar 2005 Posts: 395 Location: Budapest, Hungary
1987 Toyota Corolla AE86 (late US)
Posted: Sun Jan 14, 2007 2:14 am Post subject: |
Hopefully it contains the power sunroof circuit as well. It's not that difficult but I want to check myself if I discovered the wires correctly...
_________________ 1987 Toyota Corolla GT coupe - for holidays oversteer
2005 Toyota Corolla - for daily understeer
| Back to top |
parrot Takumi
Posted: Sun Jan 14, 2007 12:05 pm Post subject: |
The sunroof circuit is in the Euro version already listed above. Not hard, it goes from the junction box in the drivers footwell.
| Back to top |
SutteR Takumi
Posted: Sun Jan 14, 2007 12:07 pm Post subject: |
OK it's only that I have an USDM version SR5 converted to a Euro style GT. So the wiring is quite interesting but not that mess...
| Back to top |
banpei Site Admin
1982 Toyota Carina
Posted: Sun Jan 14, 2007 12:24 pm Post subject: |
| SutteR wrote: | | OK it's only that I have an USDM version SR5 converted to a Euro style GT. So the wiring is quite interesting but not that mess... |
Haha... I think we both have the same problem.
But I thoughtyou converted the front also to Levin, isn't it?
| Back to top |
SutteR Takumi
Posted: Sun Jan 14, 2007 6:20 pm Post subject: |
| banpei wrote: | Haha... I think we both have the same problem.
But I thoughtyou converted the front also to Levin, isn't it?  |
I didn't but the previous owner did. And for more mess the donor GT car was a hatchback so the chassis(?) loom has all the needed wires but mostly with the wrong plugs.
| Back to top |
banpei Site Admin
1982 Toyota Carina
Posted: Sun Jan 14, 2007 8:42 pm Post subject: |
Argh. That's even worse!
Only problem I currently have is the connector of the power mirrors not being the same: probably euro levin has a different connector than the USDM connector... It is something I need to sort out for the past year.
| Back to top |
SutteR Takumi
Posted: Sun Jan 14, 2007 10:00 pm Post subject: |
Sooo you have power mirros? Laaazy guuy...
| Back to top |
banpei Site Admin
1982 Toyota Carina
Posted: Mon Jan 15, 2007 11:21 am Post subject: |
| SutteR wrote: | Sooo you have power mirros? Laaazy guuy...  |
Real unpowered mirrors.
If I want to change the setting on my right mirror I have to ask my girlfriend to wind down the window and push the mirror by hand.
| Back to top |
SutteR Takumi
Posted: Mon Jan 15, 2007 1:59 pm Post subject: |
So you can't just drive away for a few hours to be alone with the road and the mountains...oops sorry, you don't even have mountains. It's not that Hungary would have so much of them but we have, and you've missed it in December.
| Back to top |
mrgud Takumi
Posted: Mon Jan 15, 2007 5:28 pm Post subject: |
These were verry heplfull... thanx man!!
It takes a few seconds to get the hang of it, but after that a 8year old can figure it out
_________________ SNO-MO-BIRU project started- CHIRO
| Back to top |
parrot Takumi
Posted: Fri Feb 16, 2007 6:31 am Post subject: |
Pedro-siR you have email
SutteR you have a PM and email, actually your hotmail email bounced. Let me know if the PM doesn't come thru and perhaps a different email?
| Back to top |
SutteR Takumi
Posted: Fri Feb 16, 2007 4:31 pm Post subject: |
Hi parrot, got and replied your PM. Don't use my hotmail address.
| Back to top |
parrot Takumi
Posted: Fri Mar 09, 2007 8:28 am Post subject: |
Have finally got around to scanning the USDM 1986 EWD book. It is 5mb in PDF. Banpei, I shall try to email it to you.
| Back to top |
banpei Site Admin
1982 Toyota Carina
Posted: Fri Mar 09, 2007 6:21 pm Post subject: |
Yep. Pm-ed you my emailaddress.
| Back to top |
banpei Site Admin
1982 Toyota Carina
Posted: Mon Mar 12, 2007 2:25 pm Post subject: |
Uploaded the usdm ewd:
Thanks!
| Back to top |
domi Ryousuke
Posted: Tue Mar 13, 2007 11:40 am Post subject: |
You guys are the best. That could not have come at a better time!
| Back to top |
parrot Takumi
Posted: Tue Mar 13, 2007 3:07 pm Post subject: |
Excellent, www at its best.
| Back to top |
