rear suspension setup
04-04-2006, 08:44 PM
I also think i read somewere that some hilux ones worked as shortstroke.
I will looke into it
/Skassa
"""www.turbotoys.dk"""
04-04-2006, 10:16 PM
In the front I am with TA22 shocks (I believe). They are pretty easy to find in eBay and veeery cheap, as nobody knows how perfect they fit on the hachi. As they are a bit stiffer the car handles also pretty ok.
For the rear shocks I have this list. Of course I havent tried all those options, so if trying please try to collect some more information - check if the Koni numbers are equal or so...
DAIHATSU :
CHARMANT (A)
1.3 (A35) (48 kW ; 11/1981 - 07/1987)
1.5 (A55) (09/1981 - 07/1983)
1.6 (A45) (55 kW ; 12/1981 - 09/1984)
1.6 (A60) (57 kW ; 09/1985 - 07/1987)
1.6 (A60) (60 kW ; 05/1986 - 07/1987)
1.6 (A60) (61 kW ; 08/1983 - 07/1987)
TOYOTA :
CARINA (TA1_)
1.4 (TA/RA10,30) (02/1970 - 09/1977)
1.6 (55 kW ; 02/1976 - 03/197Cool
1.6 (TA12) (58 kW ; 05/1973 - 03/197Cool
1.6 (63 kW ; 10/1975 - 03/197Cool
1.8 (TA/RA10,30) (02/1970 - 09/1977)
2.0 (TA/RA10,30) (02/1970 - 09/1977)
CELICA (TA/RA 2/3)
1.4 (TA,RA 20) (12/1970 - 09/1975)
2.0 (TA,RA 20) (12/1970 - 09/1975)
2.0 (TA/RA 23/28/35) (10/1975 - 07/1977)
CELICA (TA2)
1.6 LT (TA2) (55 kW ; 02/1976 - 03/197Cool
1.6 LT (TA22) (58 kW ; 05/1973 - 03/197Cool
1.6 ST (TA2, TA22) (63 kW ; 05/1973 - 03/197Cool
1.6 GT (TA2, TA22) (79 kW ; 12/1974 - 03/197Cool
COROLLA (_E7_)
1.3 (KE70) (44 kW ; 09/1979 - 06/1983)
1.3 (KE70) (48 kW ; 02/1982 - 06/1983)
1.6 (TE71) (55 kW ; 10/1982 - 09/1983)
1.8 D (CE70) (43 kW ; 01/1983 - 09/1983)
COROLLA Liftback (_E7_)
1.3 (KE70) (44 kW ; 09/1979 - 01/1982)
1.3 (KE70) (48 kW ; 02/1982 - 05/1983)
1.6 (TE71) (54 kW ; 09/1979 - 05/1983)
1.6 (TE71) (55 kW ; 09/1979 - 05/1983)
1.6 (TE71) (63 kW ; 09/1979 - 05/1983)
1.6 GT (TE71) (81 kW ; 05/1980 - 09/1983)
1.8 (TE72) (57 kW ; 09/1979 - 05/1982)
1.8 D (CE70) (48 kW ; 01/1983 - 09/1983)
COROLLA Coupe (AE86)
1.6 (AE 86) (08/1983 - 05/1985)
1.6 SR 16V (57 kW ; 05/1983 - 04/1987)
1.6 16V (85 kW ; 12/1985 - 04/1987)
1.6 GT 16V (AE86) (91 kW ; 08/1983 - 07/1987)
"..el camino's aren't supposed to make sense, craziness is what makes the world go around." - Car & Driver, 1984
04-05-2006, 01:10 AM
and about rear springs ? What are you using? I broke springs last year
and I don't know what to use . Stocks are a little too soft and too high( front springs lowered).The broken springs wire was 12mm(dia).
Any idea, considering it's for rallye purpose , and I don't need progressive item?
filh
Filh
Save the RWD cars
04-05-2006, 01:34 AM
My rear springs are very soft too. I guess they havent being changed for 23 years now, so I'm also looking for option for them. The cheapest way is to get them out and to try to find similar at the scrab yards. There are some from Volvo from the early 80s that will do fit... but personaly I will not go for used or different spring.
I like rally driving too, and so far I see (thanks to the old soft springsSmile) - softer springs on the back is the right setup. On tarmak with 195/60/14 the car ist very easy to be fully trottled in the turns, without loosing traction.
You could check the threads in the forum for opinions about springs. They are some very helpfull ones ...
04-05-2006, 10:26 AM
filh Wrote:and about rear springs ? What are you using? I broke springs last year
filh
Try Nissan Primera P10 rear springs.
04-05-2006, 11:03 PM
absolutly, soft stock rear springs are the good way for optimal grip , but in
situation like jumping , or in bad gravel , stock springs don't resist !
That's why I use 1mm(dia) more than the 11mm stock springs.
I don't know if there are solutions like Eibach etc .
I had mine manufactured , but it's expensive : about 150€ for 2 springs ..
I'll check for Nissan springs properties .
Filh
Filh
Save the RWD cars
04-08-2006, 08:32 AM
jamiemirror Wrote:Try Nissan Primera P10 rear springs.
They fit? Dumb question
[Image: AEU86 AE86 - rear suspension setup]
04-08-2006, 08:59 AM
From what I know about Eibach - they are shorter too.
Another question - when you lower the car (even with only 40mm) isnt it necessary to adjust the panhard rod aswell?
By my understanding the car falls down, so the panhard rod is pushing more to the left and the rear axle is not anymore centered by it.
04-08-2006, 10:11 AM
Yes. The only "problem" is that I have H&R brand sport springs for P10 so I can't say for sure what is the height of OEM P10 springs.
04-08-2006, 10:23 AM
jamiemirror Wrote:Yes. The only "problem" is that I have H&R brand sport springs for P10 so I can't say for sure what is the height of OEM P10 springs.
Ah, I see. I thought you meant oem springs. Wink
  Which is the best setup for grip?? Sgonzalez 36 45,679 02-10-2008 10:44 PM
Last Post: totta Crolla
  Rally Setup MOmo 14 22,664 04-23-2007 01:08 AM
Last Post: apardal
  Kristians track setup KristianAE86 15 20,925 09-19-2005 08:17 PM
Last Post: KristianAE86
