| Author |
Message |
Ivan141 Moderator
Joined: 06 Sep 2004 Posts: 4744 Location: Netherlands Z-H
Posted: Fri Sep 02, 2005 8:15 am Post subject: |
BTW, the hammering bit involves a metal pipe or broomstick of some sort so you can reach in there...doubt if it would have done any good..Your starter would have been fried if it was stuck and you push-started the car.
'81 poor guy with a money-pit
| Back to top |
banpei Site Admin
1982 Toyota Carina
Posted: Fri Sep 02, 2005 12:04 pm Post subject: |
| mux213 wrote: | Art, I need to get my drive on things to you, then we can easilly get underneath your car safely...
I don't know if there is a chance you can get over here tomorow night? |
Nope. My sister in law has graduation today, so I don't have time today.
| Back to top |
LevinGT Takumi
Joined: 30 Oct 2004 Posts: 215 Location: Zoetermeer-NL
Posted: Wed Dec 28, 2005 1:43 am Post subject: |
| Jan Pedersen wrote: | This is what you need:
anyone has partnumbers for those things?
_________________ Disclaimer: Any errors in spelling, tact, or fact are transmission errors.
| Back to top |
Jan Pedersen Moderator
Joined: 07 Sep 2004 Posts: 1144 Location: Herning, Denmark
Posted: Wed Dec 28, 2005 8:54 am Post subject: |
I'll try to get a hold of the part numbers next time I pay a visit to my part pusher This buy is the only one I can't find the reciept for...
_________________ Sarcasme is just one of the things I offer
| Back to top |
Posted: Tue Jan 03, 2006 8:37 pm Post subject: |
| LevinGT wrote: | | Jan Pedersen wrote: | This is what you need:
anyone has partnumbers for those things?  | "Piston" 28235 - 35080
Fittings are aftermarked from a company that has specialized in starter rebuilds, but bought at Toyota. If you are not able to get them order this part number: 28226 - 72080 (Actually for E101, but they should fit the E86 as well) Problem is that this way you are not only getting the fittings, but some extra parts which makes it more expensive
Hope this helps
| Back to top |
LevinGT Takumi
Posted: Tue Jan 03, 2006 9:15 pm Post subject: |
Thanks Jan, but I just discovered that I have a old type starter, so I can't use this kit.
But when I opened this sucker up, I saw a lot of old grease and some dirt on gear and electrical parts, did a good cleaning job and voila starter fixed.
At least for now.
This cost me 0.
Thanx anyway.
| Back to top |
Posted: Tue Jan 03, 2006 10:09 pm Post subject: |
Thats great news
| Back to top |
Ivan141 Moderator
Posted: Wed Jan 04, 2006 9:42 am Post subject: |
The old starters are pretty simple to work on...the only things that tend to wear out are the bearings and stator brushes. I just wish they had a bit more oomph during these cold days of the year when the battery is weaker.
@LevinGT: have you checked if the bearings are still okay? they are pressed into the end caps I think..mine where ground down to a thin shell.
| Back to top |
LevinGT Takumi
Posted: Wed Jan 04, 2006 1:43 pm Post subject: |
Mine aswell, where can I get some?
| Back to top |
Ivan141 Moderator
Posted: Wed Jan 04, 2006 1:49 pm Post subject: |
You need to have the new ones fitted at a shop. I just bugged the local alternator repair/refurbishing business in Spijkenisse about it and they pressed some new bearings in for me after a few grunts from the owner of the store.
Final cost was 5 euro's for the 2 new bearings. They can also replace the stator brushes if they are almost worn out..but mine where still fine.
| Back to top |
the boffin Wataru
Joined: 09 Jan 2006 Posts: 101 Location: Coupesville Northern Ireland
Posted: Sat Jan 28, 2006 5:25 pm Post subject: |
I had problem with starting, turned out to be the ignition thing behind the barrel, nothing to do with the starter at all.
Only found this out after doing up starter, new solenoid and new relay.
_________________ Listen to the whine.
Not just a carbon copy.
| Back to top |
StudeBaker Itsuki
Joined: 06 Nov 2005 Posts: 16 Location: Germany - Munich
Posted: Tue Jan 31, 2006 12:07 am Post subject: |
I have a simular problem...
If i turn the Key to start, the starter turns, the engine light turns OFF or it flickers...
Donīt know what to do!
I checked and reworked the ground connections, the batterie is full, fuel is runing!
And sometimes the engine stops while driving...
Thank you
Greetings
Martin
| Back to top |
the boffin Wataru
Posted: Thu Feb 02, 2006 7:11 pm Post subject: |
Seemed to help for a day, prob back again. If i give the key a good rattle it seems to start, some times starts first turn, other times might take 15-20 turns of key. Could barrel wear be a prob?
So far changed new circuit open relay, new starter bushes(it looks spot on), new solenoid, new key
| Back to top |
Ivan141 Moderator
Posted: Fri Feb 03, 2006 8:22 am Post subject: |
@boffin, I'd check the wiring to the ignition for slightly loose contacts... while your at it unplug the ignition barrel and measure it through with a multimeter. If it only works intermittantly, replace it I guess. Use some contact spray on the connector terminals when you put it back together.
| Back to top |
delange Ryousuke
Joined: 20 Jan 2006 Posts: 186 Location: antwerp, belgium
1983 Toyota Corolla AE86 (early Levin)
Posted: Wed Feb 08, 2006 4:20 pm Post subject: |
| StudeBaker wrote: | I have a simular problem...
Thank you
Greetings
Martin |
have had the same problem, tried testing alot of things (map-sensor,ECU,electrical wiring,...) eventually it was the fuelpump that didn't worked so good, it didn't make enough pressure while it was working & sometimes it worked great and after a few km it stopped
so fitted a new one (walbro) & engine works even better
don't know if yours is still stock?
_________________ greetzz Delange
| Back to top |
StudeBaker Itsuki
Posted: Wed Feb 08, 2006 9:58 pm Post subject: |
| delange wrote: | | StudeBaker wrote: | I have a simular problem...
Thank you
Greetings
Martin |
don't know if yours is still stock? |
thanks,
yeah, my fuel pump is still stock, maybe i should try a new one!
itīs just as you say, sometimes it stops, in every situation... slow driving or just flat out...
i will try this!
| Back to top |
Kas Takumi
Joined: 22 Nov 2004 Posts: 287 Location: Croatia, Zagreb
Posted: Sun Apr 09, 2006 9:28 pm Post subject: |
I have a problem with engine starter, but not with starter but with part which move starter gear into flywheel and make a contact betwen + pole of batery and starter motor, you know, smal piece which is screwed for starter.
Do someone know from which Toyota engines I can fit in starter or just part that moves starter gear?
_________________ 1984 Levin hatchback
2004 Kawasaki KLE 500
| Back to top |
Kas Takumi
Posted: Mon Apr 10, 2006 9:10 pm Post subject: |
Today I buy a new one, 25 .
Put everything in place, and a hachi is running again.
| Back to top |
banpei Site Admin
1982 Toyota Carina
Posted: Mon Apr 10, 2006 9:45 pm Post subject: |
| Kas wrote: | Today I buy a new one, 25 .
Put everything in place, and a hachi is running again.  |
Congrats
Do you have a partnumber? Might be a good one if others are searching for it.
| Back to top |
Kas Takumi
Posted: Sat Apr 15, 2006 8:30 pm Post subject: |
No, sorry.
I buy part in http://www.jcauto.pl/
Just bring old one, and salesman go back, and do a search and that is it.
They are very good with prices here in Croatia and we also have some discount.
| Back to top |
