Starter problems
01-03-2006, 09:15 PM
Post: #31
Starter problems
Thanks Jan, but I just discovered that I have a old type starter, so I can't use this kit.
But when I opened this sucker up, I saw a lot of old grease and some dirt on gear and electrical parts, did a good cleaning job and voila starter fixed.At least for now. This cost me € 0. Thanx anyway. Disclaimer: Any errors in spelling, tact, or fact are transmission errors. |
01-03-2006, 10:09 PM
Post: #32
Starter problems
Thats great news :!:
01-04-2006, 09:42 AM
Post: #33
Starter problems
The old starters are pretty simple to work on...the only things that tend to wear out are the bearings and stator brushes. I just wish they had a bit more oomph during these cold days of the year when the battery is weaker.
@LevinGT: have you checked if the bearings are still okay? they are pressed into the end caps I think..mine where ground down to a thin shell. FABRICA MI DIEM, PVNC! |
01-04-2006, 01:43 PM
Post: #34
Starter problems
Mine aswell,
01-04-2006, 01:49 PM
Post: #35
Starter problems
You need to have the new ones fitted at a shop. I just bugged the local alternator repair/refurbishing business in Spijkenisse about it and they pressed some new bearings in for me after a few grunts from the owner of the store.
Final cost was 5 euro's for the 2 new bearings. They can also replace the stator brushes if they are almost worn out..but mine where still fine. FABRICA MI DIEM, PVNC! |
01-28-2006, 05:25 PM
Post: #36
Starter problems
I had problem with starting, turned out to be the ignition thing behind the barrel, nothing to do with the starter at all.
Only found this out after doing up starter, new solenoid and new relay. Listen to the whine. Not just a carbon copy. |
01-31-2006, 12:07 AM
Post: #37
Starter problems
I have a simular problem...
If i turn the Key to start, the starter turns, the engine light turns OFF or it flickers... Don´t know what to do! I checked and reworked the ground connections, the batterie is full, fuel is runing! And sometimes the engine stops while driving... Thank you Greetings Martin |
02-02-2006, 07:11 PM
Post: #38
Starter problems
Seemed to help for a day, prob back again. If i give the key a good rattle it seems to start, some times starts first turn, other times might take 15-20 turns of key. Could barrel wear be a prob?
So far changed new circuit open relay, new starter bushes(it looks spot on), new solenoid, new key Listen to the whine. Not just a carbon copy. |
02-03-2006, 08:22 AM
Post: #39
Starter problems
@boffin, I'd check the wiring to the ignition for slightly loose contacts... while your at it unplug the ignition barrel and measure it through with a multimeter. If it only works intermittantly, replace it I guess. Use some contact spray on the connector terminals when you put it back together.
02-08-2006, 04:20 PM
Post: #40
Starter problems
StudeBaker Wrote:I have a simular problem...have had the same problem, tried testing alot of things (map-sensor,ECU,electrical wiring,...) eventually it was the fuelpump that didn't worked so good, it didn't make enough pressure while it was working & sometimes it worked great and after a few km it stopped so fitted a new one (walbro) & engine works even better don't know if yours is still stock? |
| Big wheel problems | gh0st | 16 | 14,308 |
| Starting problems 4-AGE kouki | Hanzo | 3 | 4,599 |
| AE86 starter options | max_ae86 | 12 | 36,896 |
07-28-2019 08:17 PM Last Post: harkes |
| Problems Mintex M1155 pads | Dino86 | 9 | 12,433 |
07-04-2017 11:22 AM Last Post: totta Crolla |
| 16v Bigport fuel problems | Rascal21 | 1 | 6,227 |
07-04-2015 01:00 AM Last Post: jondee86 |
starter fixed.
