| Author |
Message |
KristianAE86 Moderator
Posted: Sat Sep 17, 2005 10:42 pm Post subject: Kristians track setup |
Bastiaan...
Thanxs you for a great idea for a new forum
this last Wednesday i was supposed to go trackdriving at Sturup Raceway. (se picture of track)
But my broken diff -I´m having problems getting it apart - stopped me.
On the first of Octobre i´m going to Ring Knutstorp (se picture of track) just 12 kms south of me, for a whole day´s trackdriving with the Swedish honda Club.
My drift set-up is not that big in difference from the new track set-up.
Here are the differences:
Drifting set-up !
Front suspension: Coilovers to 0 percent (as soft as possible)
KÓNI´s set to SOFT
Rear suspension: KONI´s set to 85-95% stiffness
Twin swaybars installed & adjusted
front tires: TOYO T1-R 195/55-14, semi R-rated
front rims: 6,5 x 14
rear tires: TOYO Cleanproxes, 174/65-14, studless snowtires
rear rims: 6,5 x 14
Track set-up !
Front suspension: Coilovers set to 65% stiffness
Rear suspension: KONI´s set to 55% stiffness
twin swaybars still installed, but bolts loosened
front tires: TOYO R888 185/55-15 R-raded with Supersoft compound
front rims: 7 x 15
rear tires: TOYO R888 215/50-15 R-raded with Supersoft compound
rear rims: 8,2 x 15
Viewed 1402 Time(s) Click to enlarge
Viewed 1354 Time(s) Click to enlarge
_________________ I´m sorry sir, your planet has been sceduled for destruction
| Back to top |
NoHachi Moderator
Joined: 07 Sep 2004 Posts: 1998 Location: Delft - The Netherlands
Posted: Sun Sep 18, 2005 12:11 am Post subject: |
Damn, those new toyo tires should be something. The old tires they are replacing were renowned for their durability on track. Let me know how you like them.
_________________ A wheel to steer the front of the car
Scuderia Rollator
| Back to top |
Posted: Sun Sep 18, 2005 12:14 am Post subject: |
| NoHachi wrote: | | Damn, those new toyo tires should be something. The old tires they are replacing were renowned for their durability on track. Let me know how you like them. |
i belive this set-up will kick som serious Honda V-tec ass
| Back to top |
James Takumi
Posted: Sun Sep 18, 2005 2:25 am Post subject: |
| Quote: | Front suspension: Coilovers to 0 percent (as soft as possible)
KÓNI´s set to SOFT
Doesnt this make the front re-act alittle to slowly??? or is that how you want it in drifting. I would have throught you would want about 45% stiffness so that the front isnt always absorbing all the bumps and changes in the corners. Cause being stiffer would allow better steering response wouldnt it?
_________________ Triumphs without difficulties are empty. Indeed, it is difficulties that make the triumph. It is no feat to travel the smooth road
* 1984 AE85 Toyota Trueno, 3AU 1500cc (getting panel and painted)
* 1992 R32 GTS-t Skyline, RB20DET (the mrs' daily driver but I own it, strange how that works)
* 1995 Honda Accord, 2.2Ltr VTEC (My daily driver)
| Back to top |
Mux213 Site Admin
Posted: Sun Sep 18, 2005 8:53 am Post subject: |
Split this post so the announcement thread wont be filled up with subjects:)
Nice info kris:)
_________________ Greetz,
No more hachi
| Back to top |
Kir
Posted: Sun Sep 18, 2005 10:52 am Post subject: |
What's the speed differance between the R888 and the T1R in corners?
| Back to top |
Posted: Sun Sep 18, 2005 11:59 am Post subject: |
| mux213 wrote: | Split this post so the announcement thread wont be filled up with subjects:)
Nice info kris:) |
Cool Mux !
| Back to top |
Posted: Sun Sep 18, 2005 12:00 pm Post subject: |
| Kir wrote: | | What's the speed differance between the R888 and the T1R in corners? |
Kir:
T1-R is a high performance STREET tire.
R888 is an R-rated racing tire with thread.
Differences" should" be A LOT !
Although i dont know yet.
Kris
| Back to top |
gt99 Wataru
Posted: Mon Sep 19, 2005 9:54 am Post subject: |
These Toyo are awesome. They have better grip as racing slicks!!! We are racing on kart tracks (we don't call it so, but I think its AutoX). I use GY Eagle F1 GSD3 - we were very competitive until one of our competitors bought them. Now we are 3-4 seconds behind. Even in wet (F1 very good on wet surface).
| Back to top |
ZaX Moderator
Joined: 20 Sep 2004 Posts: 1427 Location: Croatia / Zagreb
Posted: Mon Sep 19, 2005 10:38 am Post subject: |
What are the specs on spring you are using?
My konis when set on soft seting could not damper enough 8kg/mm coilover springs so car would bounce a lot.
_________________
| Back to top |
Posted: Mon Sep 19, 2005 1:21 pm Post subject: |
| gt99 wrote: | | These Toyo are awesome. They have better grip as racing slicks!!! We are racing on kart tracks (we don't call it so, but I think its AutoX). I use GY Eagle F1 GSD3 - we were very competitive until one of our competitors bought them. Now we are 3-4 seconds behind. Even in wet (F1 very good on wet surface). |
gt99:
Thare are NONE R-rated tires that work well in the rain - Way to littkle thread for serioud rain attack.
Raceteam often (always) change from R888 in the dry to T1-R in the wet.
GY F1´s are great in the rain - but they on the other hand - are NOT R-rated.
| Back to top |
Posted: Mon Sep 19, 2005 1:23 pm Post subject: |
| ZaX wrote: | What are the specs on spring you are using?
My konis when set on soft seting could not damper enough 8kg/mm coilover springs so car would bounce a lot. |
Zax my man !
I do not know the springrate..
the front springs I use are from from a Chrysler Neon coilover EBAY-kit & i´m using the rear springs in the front - front springs were way to stiff.
| Back to top |
ZaX Moderator
Posted: Mon Sep 19, 2005 3:01 pm Post subject: |
| KristianAE86 wrote: | | ZaX wrote: | What are the specs on spring you are using?
Zax my man !
the front springs I use are from from a Chrysler Neon coilover EBAY-kit & i´m using the rear springs in the front - front springs were way to stiff. |
Buy a proper springs Kris, H&R has coilover springs cheap. Please don't mess with e-bay crap stuff.
AFAIR Luis from Paradiseracing can get you Q&A springs in desired spring rate and height!
_________________
| Back to top |
Guest
Posted: Mon Sep 19, 2005 8:16 pm Post subject: |
| ZaX wrote: | | KristianAE86 wrote: | | ZaX wrote: | What are the specs on spring you are using?
Zax my man !
AFAIR Luis from Paradiseracing can get you Q&A springs in desired spring rate and height! |
I don´t need to - since these work great !
| Back to top |
Posted: Mon Sep 19, 2005 8:17 pm Post subject: |
| Anonymous wrote: |
I don´t need to - since these work great ! |
That was mee.
| Back to top |
