Richieu -Technical help desk
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Technical
Author Message
richieu
Wataru
PostPosted: Sat Sep 17, 2005 10:15 am    Post subject: Richieu -Technical help desk Reply with quote
OK
Here you can ask questions and read tips on how to restore your beloved AE86. This thread will only relate to the bodywork, fixtures and fittings of the car not electrics and mechanical as I have only so much time I can spend in the evenings answering questions
Don't be affraid to ask even if it sounds stupid, we all had to start somewhere and if you do it right first time it will mean you can move on to another part of your build quicker. Thumbsup
_________________
Back to top
View user's profile Send private message AIM Address
nmwisima
Bunta
1996 Mazda MX-5
PostPosted: Sat Sep 17, 2005 11:11 am    Post subject: Reply with quote
No questions yet, but thats a nice thought. Thanx Cheerleader
p.s Here's one: Is there any way to prevent rear hatch from rusting all the time?
_________________
Back to top
View user's profile Send private message Send e-mail
James
Takumi
PostPosted: Sat Sep 17, 2005 1:19 pm    Post subject: Reply with quote
Good to see my suggestion didnt go unnoticed Cool
If I have rust holes or just rust starting out in my pannels is it ok to use rust convertor and then use body filler over it rather than having to cut it out and weld new panels in places.???
I have little rust spots that im fixing now and once I do all the body filler and paint I dont want the rust to re apair but this rust convertor which you paint on says it will stop rust from "growing". Whats your thoughts on this?
_________________
Triumphs without difficulties are empty. Indeed, it is difficulties that make the triumph. It is no feat to travel the smooth road
* 1984 AE85 Toyota Trueno, 3AU 1500cc (getting panel and painted)
* 1992 R32 GTS-t Skyline, RB20DET (the mrs' daily driver but I own it, strange how that works)
* 1995 Honda Accord, 2.2Ltr VTEC (My daily driver)
Back to top
banpei
Site Admin
1982 Toyota Carina
PostPosted: Sat Sep 17, 2005 2:33 pm    Post subject: Reply with quote
I moved the topic to the Question and Answer section. Wink
Question: Any experience with rust on a sunroof? Blonde question
_________________
Back to top
View user's profile Send private message Visit poster's website Yahoo Messenger MSN Messenger Skype Name
richieu
Wataru
PostPosted: Sat Sep 17, 2005 3:26 pm    Post subject: Reply with quote
Rust the enemy of all AE86's
If you adopt the following rules regarding rust you wont go wrong!
Rust is caused by the oxidisation of metal in the atmosphere. All steel rusts from the minute it is exposed as an example we shot blasted a shell the other night and because it was a nice summer evening with no rain forecast we decided to leave it outside the workshop till morning. When we arrived the next morning the whole shell had gone orange, this was the start of the metal oxidising.
There are various factors which can speed up the rate of rusting the biggest cause is salt. You will notice that norther European cars tend to rust quicker and more severely that southern European cars this is because in notrthern Europe the climate is wetter and we use a lot of salt to keep the roads from icing up.
How to deal with rust.
Its important to not only get rid of the rust you can see but treatr the area to get the rust you cant see.
For example in nmwisima's casethe rust scabs should be rubbed down with say 120 grit wet and dry to remove the high spots and to smooth the area (you can use water with the wet and dry paper as this helps to clean the paper as its working)
Make sure you go 5% larger than the rust area back to shiney clean steel.
Once you have done this apply a rust converter (chemical that neutralises rust using ferric acid) this will convert the rust to an innert skin that will never rust again. Once you have done this and let it cure cover over the area with body filler or body putty (knifing compound or stopper in the UK). Let this cure fully and than rub down with wet and dry paper and a block starting with 240 grit working to 1200grit, by this time you should end up with a really smooth finish.
Now close your eyes and very gently run the tips of your fingers over the area, you should not feel any bumps or dips if you do you need to either rub them down or fill them, if not wash with mild washing up liquid and water and then dry the area thoroughly using a heat gun or hair dryer.
Mask off the area and warm it up with the heat gun so that it is warm to the touch, this ensures that the area is completely dry and the primer will adhere and dry on contact. Build up the l;ayers of primer allowing each coat to dry before applying the next (say 4 to 5 coats)
Once the primer is dried (leave over night or in the sun if you can) rub it smooth with 1200 grit wet and dry paper and then 2400 grit to finish.
wash and dry as you did at the start then apply several light coats of paint by aerosol of spray gun like this,
1st coat very light and leave for say 5 minutes (called tack coat) this provides a good bonding coat for the other coats)
apply second coat moving leaft to right and leave for 3 minutes
apply 3rd coat moving up and down
4th coat should be left to right and finish with diagonal strokes.
Finally just as the 4th coat is about to dry apply a heavier coat (move slightly slower with a can or increase thinners in spray gun)
What wll happen is that the solvent in the final coat will migrate down through the other drying coats and a shine will start to appear. Dont worry if this doesnt happen we have enough paint on to remedy. Leave to dry thoroughly ( six hours minimum or overnight). Remove masking and forget about it for atleast a week as th paint need to harden.
After a week take some of the 2400 wet & dry paper you used on the primer and some soapy water and a rubbing block and gently move over the area painted and the surrounding painted area, this will blend in the repair. once you have a dull finish all over dry with a rag and then apply some T Cut or rubbing compound rubin in circled and straight lines untill the area shines when you wipe with a dry soft cloth. Leave this now for another two weeks as the sremaining solvent needs to leave the paint and it can cure. after two weeks apply a good high solids polymer wax or silicone coating and buff of with a dry rag.
Voila!!! Repair done Thumbsup
_________________
Back to top
richieu
Wataru
PostPosted: Sat Sep 17, 2005 3:31 pm    Post subject: Reply with quote
James
Depending upon the size of the hole say no more than a finger nail, tap in the hole with a rounded hammer to make a crater. Put some filler on som card and stick it to the back of the hole (from inside if you can). If you cant do this use fibreglass bonding filler P38 and slightly fill the crater. Let this cure and then use an easy sand body filler to fill up the rest of the crater leaving the filler slightly proud of the hole.
When this has gone off use some 120 grit paper and a rubbing block and move over the whole area untill the surface is smoothe with the rest of the panel.
Then carry out the riming and painting as in the above post.
Thumbsup
_________________
Back to top
James
Takumi
PostPosted: Sun Sep 18, 2005 1:55 am    Post subject: Reply with quote
You are the man!!! Thanks for that awesome info. This should be made a sticky!!!
_________________
Back to top
Mux213
Site Admin
PostPosted: Sun Sep 18, 2005 8:49 am    Post subject: Reply with quote
And a sticky it is, really nice to hear this from someone with experience !Smile
_________________
No more hachi Sad
Back to top
James
Takumi
PostPosted: Tue Sep 20, 2005 8:19 am    Post subject: Reply with quote
Ive just stripped down my drivers side door. Theres a slight dent in the door and some one had put filler over top to hid it then they painted over it with anti rust paint. However they did a bad job and the paint cracked. So thats why I stripped it. Once there was metal showing where the filler was I used Rust Netuliser which is meant to netulise the rust the I used Rust Convertor over that. Now I will use body filler to smooth over and then primer it then paint. Is this a correct once of protecting it from getting rusted in future.
Cheers
_________________
Back to top
richieu
Wataru
PostPosted: Fri Sep 23, 2005 1:50 pm    Post subject: Reply with quote
Hi James
Remove all existing filler from dent
Scratch the dented area with a knife or sharp blade in a criss cross pattern ( this gives the filler something to cling to as door skins flex a lot)
Apply a coat of rust converter only if rust is evident then carry out repair with filler as above
Good luck, if you need any further help just ask
Cheers Richie
_________________
Back to top
Ivan141
Moderator
PostPosted: Fri Sep 23, 2005 2:37 pm    Post subject: Reply with quote
Hi Richie,
I have a good one for you too...pics coming on sunday.
My coupe has a lot of lap welds that are starting to rust, or have rusted away quite a bit already. What's the best way to stop this where it hasnt made things crunchy yet? And what to do with the places where the rust has done it's damage....the weird thing is that it mostly rusts on one side of the lapwelds..
I have this problem around the seams of the rear panel, on my right sill, and more disturbingly behind the door at the front of the body (there is a horizontal seam there that has rusted through. I get the feeling that these lap-weld seams are the biggest design-flaw as far as rust-sensitivity is concerned.
_________________
'81 poor guy with a money-pit
Back to top
richieu
Wataru
PostPosted: Fri Sep 23, 2005 10:12 pm    Post subject: Reply with quote
Hi Ivan,
Post me some pictures and I'll be able to provide the correct solutioon to your problem.
There are several methods of dealing with this problem so its best I see befor advising
Richie Thumbsup
_________________
Back to top
Mux213
Site Admin
PostPosted: Mon Oct 03, 2005 7:14 pm    Post subject: Reply with quote
Irishtwincam, I'm moving your post to the sell section if you dont mind, you are on the verge of breaking forum rules but I'm sure your advert will make some people on this board very happy.
*edit*
Oops, would be nice to add a linky to the new thread:)
http://www.aeu86.org/viewtopic.php?t=1918
_________________
No more hachi Sad
Back to top
ganbo
PostPosted: Sat Jun 17, 2006 2:01 pm    Post subject: Reply with quote
Hi Richie, heres a good one for you, I'm above average height 6'6" and would like to fit a fixed back bucket seat in my car. It needs to be as low as possible and quite far back, the front edge of the seat somewhere around halfway betweeen the original front and rear mountings. What would be the best way to do this? Thanks
Back to top
Garth
Wataru
PostPosted: Tue Sep 12, 2006 2:37 pm    Post subject: Reply with quote
Richie is one of the best AE86 boyo's i know. Bought a tailgate off him earlier this year. Very helpfull. See out on the Meirion Rich?
_________________
Bang her in 1st and make her Tramp
Toyota Corolla AE86 GT Rally Car
E30 BMW 318is Road Rally Car
Peugeot 205 Gti Rally Car (For Sale)
Wanted 2-Door Volvo 340 (I need cheap Drifting)
Back to top
richieu
Wataru
PostPosted: Tue Oct 17, 2006 5:54 pm    Post subject: Reply with quote
Hi Garth,
Thanks for the compliments!. Hows your roller coming on then?
Wasnt able to do the Meirion due to nav not being able to get regs in early enough to get an entry.
Wait till you see what I'll be out in for 2007 anwcc championship, you'll shit when you see what it goes like!
_________________
Back to top
Ivan141
Moderator
PostPosted: Tue Oct 17, 2006 9:28 pm    Post subject: Reply with quote
richieu!..I've missed you round these parts the last months.. how's things going?
_________________
Back to top
richieu
Wataru
PostPosted: Sat Feb 24, 2007 12:17 am    Post subject: Reply with quote
Hi Ivan and all,
Sorry havent been on for a couple of months (too much work building customers cars).
Hope to be around on here a lot more now so get your questions in.
Thumbsup Thumbsup Thumbsup
_________________
Back to top
richieu
Wataru
PostPosted: Sat Feb 24, 2007 12:28 am    Post subject: Reply with quote
Ok you are going to need a side mounted seat for starters (with side mounts obviously)
The easiedt way to get the seat down and as far back as you need to go is to do the following.
1. drill 2 8 or 10mm holes in each mount close to the ends of the bottom of the mount.
2. wind on a nylock nut to secure the bolts in place.
3.fit the side mounts to the seat and place the seat where you feel the most comfortable. You should now have the mounts sitting with the 4 bolts on the floor.
4.if you need the seat lower you will need to drill holes in the side mounts to get the seat as low as possible in the mounts.
5. once the seat is in the ideal position mark the bolts positions and drill through the floor (check for obstructions like fuel and brake lines before drilling)
6. before pushing the bolts through place the largest washers you can find to help spread the load.
7. place the same type of washers underneath and bolt them up.
8. You might need to pack the bolts with washers to level the seat once bolted.
Hope this helps if not let me know and I'll take you to plan B! (requires welding)
Thumbsup
_________________
Back to top
20vWill
Takumi
PostPosted: Tue Mar 20, 2007 4:35 pm    Post subject: Reply with quote
Hey Richie
I need the Richieu Technical Help Desk to tell me how to contact you mate!
Tried your phone loads of times but always on answerphone... Remember you said you were going to box my Supra wheels up for me in pairs so I could get them couriered?
PM me or give me a call mate!
Ta
Will
Back to top
crucifycry
PostPosted: Sun Aug 24, 2008 4:35 pm    Post subject: $age Engine And Gearbox Problem... HELP Reply with quote
Help!!!!... Anybody can help me about my engine and gearbox 4AGE? My engine 4age always got sound like KerKkkkk KerkKkkkk KerKkKk when my aircon turn On.. and before that my sound engine working normally.. when i replace my gearbox the sound strange coming then i have replace back with other gearbox the sound still hear.. Huh.. i have spent more money to buy a 2nd gearbox.. What going on my engine? I dont know the sound coming from my engine or my gearbox... ANYBODY CAN HELP ME OR TELL ME WHAT TO DO.. (I Have replace my flywheel original 4AGE to flywheel steel toda racing) any effect from there?
Back to top
View user's profile Send private message Send e-mail Yahoo Messenger
Display posts from previous:
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Technical All times are GMT + 2 Hours
Page 1 of 1
Jump to:
