Starter problems
Goto page Previous  1, 2
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Technical
Author Message
Ivan141
Moderator
PostPosted: Fri Sep 02, 2005 8:15 am    Post subject: Reply with quote
BTW, the hammering bit involves a metal pipe or broomstick of some sort so you can reach in there...doubt if it would have done any good..Your starter would have been fried if it was stuck and you push-started the car.
_________________
'81 poor guy with a money-pit
Back to top
banpei
Site Admin
1982 Toyota Carina
PostPosted: Fri Sep 02, 2005 12:04 pm    Post subject: Reply with quote
mux213 wrote:
Art, I need to get my drive on things to you, then we can easilly get underneath your car safely...
I don't know if there is a chance you can get over here tomorow night?
Nope. My sister in law has graduation today, so I don't have time today. Neutral
_________________
Back to top
View user's profile Send private message Visit poster's website Yahoo Messenger MSN Messenger Skype Name
LevinGT
Takumi
PostPosted: Wed Dec 28, 2005 1:43 am    Post subject: Reply with quote
Jan Pedersen wrote:
This is what you need:
anyone has partnumbers for those things? Blonde question
_________________
Disclaimer: Any errors in spelling, tact, or fact are transmission errors.
Back to top
View user's profile Send private message Send e-mail
Jan Pedersen
Moderator
PostPosted: Wed Dec 28, 2005 8:54 am    Post subject: Reply with quote
I'll try to get a hold of the part numbers next time I pay a visit to my part pusher Smile This buy is the only one I can't find the reciept for...
_________________
Back to top
View user's profile Send private message Visit poster's website MSN Messenger
Jan Pedersen
Moderator
PostPosted: Tue Jan 03, 2006 8:37 pm    Post subject: Reply with quote
"Piston" 28235 - 35080
Fittings are aftermarked from a company that has specialized in starter rebuilds, but bought at Toyota. If you are not able to get them order this part number: 28226 - 72080 (Actually for E101, but they should fit the E86 as well) Problem is that this way you are not only getting the fittings, but some extra parts which makes it more expensive Sad
Hope this helps Wave
_________________
Back to top
LevinGT
Takumi
PostPosted: Tue Jan 03, 2006 9:15 pm    Post subject: Reply with quote
Thanks Jan, but I just discovered that I have a old type starter, so I can't use this kit.
But when I opened this sucker up, I saw a lot of old grease and some dirt on gear and electrical parts, did a good cleaning job and voila Cheerleader starter fixed.
At least for now.
This cost me € 0. Cheerleader Cheerleader
Thanx anyway. Thumbsup
_________________
Back to top
Jan Pedersen
Moderator
PostPosted: Tue Jan 03, 2006 10:09 pm    Post subject: Reply with quote
Thats great news Exclamation
_________________
Back to top
Ivan141
Moderator
PostPosted: Wed Jan 04, 2006 9:42 am    Post subject: Reply with quote
The old starters are pretty simple to work on...the only things that tend to wear out are the bearings and stator brushes. I just wish they had a bit more oomph during these cold days of the year when the battery is weaker.
@LevinGT: have you checked if the bearings are still okay? they are pressed into the end caps I think..mine where ground down to a thin shell.
_________________
Back to top
LevinGT
Takumi
PostPosted: Wed Jan 04, 2006 1:43 pm    Post subject: Reply with quote
Mine aswell, Shocked where can I get some?
_________________
Back to top
Ivan141
Moderator
PostPosted: Wed Jan 04, 2006 1:49 pm    Post subject: Reply with quote
You need to have the new ones fitted at a shop. I just bugged the local alternator repair/refurbishing business in Spijkenisse about it and they pressed some new bearings in for me after a few grunts from the owner of the store.
Final cost was 5 euro's for the 2 new bearings. They can also replace the stator brushes if they are almost worn out..but mine where still fine.
_________________
Back to top
the boffin
Wataru
PostPosted: Sat Jan 28, 2006 5:25 pm    Post subject: Reply with quote
I had problem with starting, turned out to be the ignition thing behind the barrel, nothing to do with the starter at all.
Only found this out after doing up starter, new solenoid and new relay.
_________________
Listen to the whine.
Not just a carbon copy.
Back to top
StudeBaker
Itsuki
PostPosted: Tue Jan 31, 2006 12:07 am    Post subject: Reply with quote
I have a simular problem...
If i turn the Key to start, the starter turns, the engine light turns OFF or it flickers...
Donīt know what to do!
I checked and reworked the ground connections, the batterie is full, fuel is runing!
And sometimes the engine stops while driving...
Sad
Thank you
Greetings
Martin
Back to top
the boffin
Wataru
PostPosted: Thu Feb 02, 2006 7:11 pm    Post subject: Reply with quote
Seemed to help for a day, prob back again. If i give the key a good rattle it seems to start, some times starts first turn, other times might take 15-20 turns of key. Could barrel wear be a prob?
So far changed new circuit open relay, new starter bushes(it looks spot on), new solenoid, new key
_________________
Back to top
Ivan141
Moderator
PostPosted: Fri Feb 03, 2006 8:22 am    Post subject: Reply with quote
@boffin, I'd check the wiring to the ignition for slightly loose contacts... while your at it unplug the ignition barrel and measure it through with a multimeter. If it only works intermittantly, replace it I guess. Use some contact spray on the connector terminals when you put it back together.
_________________
Back to top
delange
Ryousuke
1983 Toyota Corolla AE86 (early Levin)
PostPosted: Wed Feb 08, 2006 4:20 pm    Post subject: Reply with quote
Sad
Thank you
Greetings
Martin
have had the same problem, tried testing alot of things (map-sensor,ECU,electrical wiring,...) eventually it was the fuelpump that didn't worked so good, it didn't make enough pressure while it was working & sometimes it worked great and after a few km it stopped Mad
so fitted a new one (walbro) & engine works even better
don't know if yours is still stock?
_________________
greetzz Delange
Back to top
View user's profile Send private message Send e-mail Visit poster's website
StudeBaker
Itsuki
PostPosted: Wed Feb 08, 2006 9:58 pm    Post subject: Reply with quote
Sad
Thank you
Greetings
Martin
thanks,
yeah, my fuel pump is still stock, maybe i should try a new one!
itīs just as you say, sometimes it stops, in every situation... slow driving or just flat out...
i will try this!
Back to top
Kas
Takumi
PostPosted: Sun Apr 09, 2006 9:28 pm    Post subject: Reply with quote
I have a problem with engine starter, but not with starter but with part which move starter gear into flywheel and make a contact betwen + pole of batery and starter motor, you know, smal piece which is screwed for starter.
Do someone know from which Toyota engines I can fit in starter or just part that moves starter gear?
_________________
1984 Levin hatchback
2004 Kawasaki KLE 500
Back to top
Kas
Takumi
PostPosted: Mon Apr 10, 2006 9:10 pm    Post subject: Reply with quote
Today I buy a new one, 25 €.
Put everything in place, and a hachi is running again. Cool
_________________
Back to top
banpei
Site Admin
1982 Toyota Carina
PostPosted: Mon Apr 10, 2006 9:45 pm    Post subject: Reply with quote
Congrats Smile
Do you have a partnumber? Might be a good one if others are searching for it. Smile
_________________
Back to top
Kas
Takumi
PostPosted: Sat Apr 15, 2006 8:30 pm    Post subject: Reply with quote
No, sorry.
I buy part in http://www.jcauto.pl/
Just bring old one, and salesman go back, and do a search and that is it.
They are very good with prices here in Croatia and we also have some discount.
_________________
Back to top
Display posts from previous:
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Technical All times are GMT + 2 Hours
Page 2 of 2
Jump to:
