  Home    shopshop    Garage  Forum RSS feed of our forumsForum RSS   FAQ   Search  Memberlist   Register    Log in
nzae86's TRD ae86 N2 Race Car Project 2
Goto page Previous  1, 2, 3 ... 9, 10, 11, 12  Next
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Projects
Author Message
einneb
Ryousuke
PostPosted: Sun Sep 27, 2009 10:38 pm    Post subject: Reply with quote
why do you use a airbox ?
_________________
Official Toyota fan.
-: Initial D :-
Back to top
nzae86
Ryousuke
PostPosted: Tue Sep 29, 2009 11:31 am    Post subject: Reply with quote
By using an air box you can draw cold air away from the engine and with the filter further away from the end of the throttle bodies there is no interference with the air speed and flow.
_________________
Your addiction to motorsport can only be cured by poverty !!
Back to top
einneb
Ryousuke
PostPosted: Tue Sep 29, 2009 2:10 pm    Post subject: Reply with quote
ah oke Smile
_________________
-: Initial D :-
Back to top
nzae86
Ryousuke
PostPosted: Thu Oct 01, 2009 6:22 am    Post subject: Reply with quote
Today the final hole in the body shell was filled with a new laminated windscreen, also another interesting discovery made as well . I lot of people here have had trouble getting a new replacement screen for these cars as the new ones all appear to be too short .Toyota have made two different scuttle panels that fit under the windscreen , one fits the original toughened glass screens from the factory and the other fits the cars that left the factory with a laminated screen that is shorter in height .All that can be purchased here in NZ is a laminated screen .
Here is a photo of the two different panels
AE86 : Projects > nzae86s TRD ae86 N2 Race Car  Project 2
Well you learn something everyday!
Nice and shiny!!
Managed to get a bit of work done on fitting the dash in and fitting up the center console, this takes the reservoirs for the master cylinders on the pedal box , also it will give me something to mount the fuse boxes and relays to as well
so the inside is starting to come together finally .
_________________
Back to top
Kid Karola
Takumi
1983 Toyota Corolla AE86 (early Levin)
PostPosted: Thu Oct 01, 2009 4:37 pm    Post subject: Reply with quote
I noticed that on my windscreen too when I replaced it due to a chip/crack, although the laminated screen I took out wasn't original either. I should have ordered the shorter panel when I got new sides and top trims... but the longer panel is ok (If it was short panel short screen then Confused )
I maybe would have mounted the remote reservoirs on the firewall behind the dash just to keep the interior less congested... but makes for easy access and keep fluid levels in check.
_________________
RokuSteady : The Chosen Few - Representing True Kanagawa Style : 神奈川 様式
Shakotan - Tsuraichi - Hippari - Onikyan
Back to top
nzae86
Ryousuke
PostPosted: Sun Nov 01, 2009 12:39 am    Post subject: Reply with quote
It's a while since I have posted any photos of progress , I have been working away slowly joining all the dots together , with things like dash , clutch and brake lines, and a lot of bits and pieces.
The new filter arrived for the end of the air box , and should allow a good flow without any restriction, I still need to make a alloy shield around the radiator side of the filter to keep the warm air from passing through the radiator and into the intake ,
Also found a suitable coil pack and mounted that up, pity its from a Ford!
Also had a bit of a move around of things in the workshop so I could get the new car on the hoist , so it got it's first taste of the outdoors! I decided that it doesn't look too bad either !!
The rest of the signage should be done this week so will post a pic of it when done .
_________________
Back to top
robokill
Bunta
PostPosted: Sun Nov 01, 2009 1:06 am    Post subject: Reply with quote
Thumbsup Drool I love the Levin TRD N2 Very Happy Great build incredible work
_________________
"08 Honda Civic Hybrid
"84 AE86 Zenki Blue Levin (project racer) http://www.cardomain.com/ride/613398
KIS it
Keep It Sideways
Back to top
Ivan141
Moderator
PostPosted: Sun Nov 01, 2009 12:25 pm    Post subject: Reply with quote
Awesome car! One little thing though: why use a nice airbox like that and then fit a whopper of an open airfilter right in front of it? Seems a shame to let it suck up hot engine bay air...
_________________
'81 poor guy with a money-pit
Back to top
Kid Karola
Takumi
PostPosted: Sun Nov 01, 2009 1:49 pm    Post subject: Reply with quote
how long until it fires up into life?
_________________
Back to top
banpei
Site Admin
1982 Toyota Carina
PostPosted: Sun Nov 01, 2009 4:49 pm    Post subject: Reply with quote
I love the colors! Thumbsup
_________________
Back to top
View user's profile Send private message Visit poster's website Follow me at Twitter Yahoo Messenger MSN Messenger Skype Name
nzae86
Ryousuke
PostPosted: Mon Nov 02, 2009 5:35 am    Post subject: Reply with quote
Like I said in my post I am yet to make a shield to stop it from ingesting warm air from the radiator , what would you do to guarantee a unrestricted supply of filtered air ? I listen to any ideas . Remember the further the air has to travel through pipes more restriction and disturbance is created .
_________________
Back to top
nzae86
Ryousuke
PostPosted: Mon Nov 02, 2009 5:40 am    Post subject: Reply with quote
Hi I'm hoping that it should come to life around Christmas time , depending on my work commitments , I have just purchased the rear brakes and have sorted the front rotors now to fit the wilwood 4 pots in a 13'' wheel, plus more wiring and all the small bits and pieces that appear to consume large amounts of time .
_________________
Back to top
Ivan141
Moderator
PostPosted: Mon Nov 02, 2009 11:49 am    Post subject: Reply with quote
Ah, missed the part about making an enclosure for it... sounds like a sound idea to me. Most racecars running serious airboxes use ridiculously wide diameter piping to the front end of the car.
A well-insulated enclosure will do the trick as well I suppose. Might be worth your while to experiment a bit with cold air feeds to the enclosure, but the problem would still be that an enclosure is unlikely to seal good enough to build any positive pressure.
Not sucking up hot air is a good place to start i reckon.
_________________
Back to top
Jimmi The Kid
Wataru
PostPosted: Mon Nov 02, 2009 6:48 pm    Post subject: Reply with quote
Why not building a Ram-Air intake, a funnel ind the front, mayby with a integrated airfilter and a big pipe up to your airbox?
_________________
AE86 newbie - but 20v oldie...
Project AE86 now begun.
Cars I have owned:
Toyota Starlet EP91 1,3 16v
Toyota Starlet EP71 1,3 12v Sport
Mercedes 207D camper, 1977.
Toyota Starlet EP70 with a 174hp Silvertop 20v See video here:
http://videos.streetfire.net/search/Starlet/0/4...-984601079edc.htm
Toyota Corolla AE101 with a 164hp Silvertop 20v. (Evolution bodykit and candycolor paint).
Volvo 240 2,1 (The only car I have maked money on).
Toyota Corolla EE90 (my first car)
Back to top
View user's profile Send private message Send e-mail
nzae86
Ryousuke
PostPosted: Tue Nov 03, 2009 8:10 am    Post subject: Reply with quote
One thing that I don't want to do to this body shell is to start cutting away the front panel, also I want to keep the flow of air as unrestricted as possible ,that is why I chose a large K&N filter to get the largest surface area of air,it also has a 4'' inlet to get the maximum amount of air to the airbox, so it may end up as a compromise to build a shield around the filter and house it all in the engine bay.Taking a cold feed without a filter will destroy my very expensive engine in a short time .Also with the data logging that I have in this car I will be able to keep a track of intake air temp and if it is a problem I will try something else
Here is what I have on my rally car , there is a good flow of fresh air from around the headlight area
This engine is not quite as radical as my track car so its air supply is not so critical.
_________________
Back to top
NoHachi
Moderator
PostPosted: Tue Nov 03, 2009 9:37 am    Post subject: Reply with quote
Hiya, amazing build Smile
Have you ever taken a look at the articles over at autospeed.com? They have done a lot of interesting experimentation on air filters, cold air intakes, ram air etc. Might provide some inspiration?
_________________
Back to top
Speedline
Iketani
PostPosted: Tue Nov 03, 2009 10:06 am    Post subject: Reply with quote
Hi, very nice build (not read the entire topic).
Regarding the fluid reservoirs for the pedal box. Aren't you afraid when you build up lateral G in a right corner that fluid will be pulled away from the cylinders?
With remote reservoir it's probably a better idea to keep the reservoirs exactly above the cylinders to avoid problems with fluid shifting due to cornering force.
Just my 2 cents.
Back to top
View user's profile Send private message Send e-mail MSN Messenger
nzae86
Ryousuke
PostPosted: Tue Nov 03, 2009 11:21 am    Post subject: Reply with quote
Just my 2 cents.
Thanks for your comments ,
I think that the remote reservoirs will hold enough head of pressure in them that the only time that there will be a lack of fluid at the master cylinder is when the car is upside down . It makes no difference whether the reservoirs are directly above or to one side of the master cylinder as the forces on it are the same .
cheers
_________________
Back to top
roman
Wataru
PostPosted: Tue Nov 03, 2009 12:01 pm    Post subject: Reply with quote
Just read the entire thread, fantastic build.
I aspire to be able to build a car to a similar quality one day.
It's also great to see your patience and persistence in answering questions about the build.
One question about your TRD injection manifold...
Almost everyone who I've talked to has insisted that the best way for trumpets is to have a large radius/lip, and the trumpets projecting into an open space, rather than flush mounted against a plate. As apparently a lot of the air flow comes from up around the sides.
How did the original TRD setup operate, were they enclosed in a box?
I have seen another picture that had a carbon fibre box on the end of what appears to be the TRD injection manifold, but with bellmouth extensions on it.
Back to top
robokill
Bunta
PostPosted: Tue Nov 03, 2009 12:58 pm    Post subject: Reply with quote
nzae86, why not make an air box in front of the wheel then make a hole up in the front wheel arch so that you can make a top enclosure for it. Then make a big air sucking piece in the front bumper to connect it to.
Then it would get driving wind pushed into the airbox which can be suckted up by the air filter.
_________________
KIS it
Keep It Sideways
Back to top
Kid Karola
Takumi
PostPosted: Tue Nov 03, 2009 3:16 pm    Post subject: Reply with quote
Is that a AE101 airbox turned around? looks neat! I recall the T3 ITB manifold mounts the throttles upside down.
_________________
Back to top
nzae86
Ryousuke
PostPosted: Tue Nov 03, 2009 7:35 pm    Post subject: Reply with quote
Hi thanks for the link , I have had a read through their articles and I think I'm heading in the right direction.
cheers
_________________
Back to top
nzae86
Ryousuke
PostPosted: Tue Nov 03, 2009 7:46 pm    Post subject: Reply with quote
These throttle bodies where used on the later Atlantic cars with an air box to suit the swift and ralt chassis , the did run a very small trumpet on the end , but the throttle body has a machined bell mouth in it as part of it's manufacture. I suppose TRD would have done a huge amount of testing on their setup , as you can see that this is the later setup where they ran the injectors from underneath the body , firing the fuel to the top of the inlet port giving it better atomization and swirl.
_________________
Back to top
nzae86
Ryousuke
PostPosted: Tue Nov 03, 2009 7:58 pm    Post subject: Reply with quote
Good idea , but not wanting to cut any holes is an issue , the other simple option is what the Toyota factory teams did back in the days when they ran these cars as group N , as the rules on radiator size was free , they made a radiator about 6'' narrower than standard , then built a vertical intake beside the radiator and ducted the air towards the throttle body intake .
I know that a cold air supply is important but in a 4age rwd car the exhaust is on the other side of the engine bay and when I have the headers coated the heat output is a lot lower and there is no turbo generating large amounts of heat .In all my time of racing and rallying these cars we have never had an issue. I like the theory of" Keep It Simple"
_________________
Back to top
nzae86
Ryousuke
PostPosted: Tue Nov 03, 2009 8:04 pm    Post subject: Reply with quote
[quote="Kid Karola"]
Good spotting , yes it is from a ae101 but I reshaped it alot to give the box more volume by cutting and welding a complete new shape to the part that bolts to the intake , as you can see the sides of the air box are now vertical, then a made a mold from my new shape then made my air box from fiber glass.
The T3 adapter does mount the bodies up the other way however I built my own and mounted the bodies up the normal way.
cheers
_________________
Back to top
Display posts from previous:
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Projects All times are GMT + 2 Hours
Page 10 of 12
Jump to:
You cannot attach files in this forum
