| Author |
Message |
Jimmi The Kid Iketani
Posted: Mon Apr 20, 2009 9:39 pm Post subject: Under shim bucket kit qustion |
Hi guys
I'm building my AE86 for grip race and will try to get almost the same engine spec as the N2 car.
I allready got some really nice parts, like TRD Atlantic con rods, a highly modified smallport head (yes I know N2 uses bigport head, but this one was cheap), TODA 4-2-1 header, ITB's and so on.
But I wonder about the valve train and springs, as I will run with a highlift cam, 10-11mm and mayby up to 9500rpm.
TODA have a full under bucket shim kit including springs, but it is very very expensive, and I cant find some adjustment shims for it. That is ofcouse really nesesary.
They also have some normally upratet springs, but are these the same springs as in the under bucket shim kit?
If they are the same springs, mayby I could use them together with the 2NZ buckets, as I can get them on my work.
Have anybody tryed this setup with results??????????
_________________ AE86 newbie - but 20v oldie...
Project AE86 now begun.
Cars I have owned:
Toyota Starlet EP91 1,3 16v
Toyota Starlet EP71 1,3 12v Sport
Mercedes 207D camper, 1977.
Toyota Starlet EP70 with a 174hp Silvertop 20v See video here:
http://videos.streetfire.net/search/Starlet/0/4...-984601079edc.htm
Toyota Corolla AE101 with a 164hp Silvertop 20v. (Evolution bodykit and candycolor paint).
Volvo 240 2,1 (The only car I have maked money on).
Toyota Corolla EE90 (my first car)
| Back to top |
totta Crolla Takumi
Posted: Mon Apr 20, 2009 10:07 pm Post subject: |
I'm using 9.5mm lift cams with HKS springs with followers (buckets) from here:
http://www.arrowprecision.co.uk/shims_stock.php
They also do top hat shims to suit and they are available in 16 off or 100 off. I thought they were real expensive but then I realised I was looking at buying 100 of 'em !
Works fine with the cams / springs and a good price too.
_________________ "accidents are rare but you're a long time dead"
| Back to top |
tolisspi Bunta
Joined: 24 Jan 2008 Posts: 855 Location: Greece-Korinthos
Posted: Mon Apr 20, 2009 10:12 pm Post subject: |
You can use the 1szfe of yaris for underbucket shims(maybe the are of 2szfe, i dont know)
I have use them with the toda 's valve springs for 10,5 lift camshafts w/o problem.
I think the valve springs of toda nad the valve spring of the kit are the same. But you can send an email to toda for your question.
Good luck for your project but i wd like more info about your ecu ect
_________________ **COROLLA EE80 - 4AGE 124HP**
| Back to top |
gon Takumi
Posted: Mon Apr 20, 2009 10:17 pm Post subject: |
don't know about running more than 9,5 10mm of lift without really good valve seats and springs .....
but back to the underbucket shims
just get the yaris ones .
i know 2 cars running them without a prob.
one is running 9,5mm the other 10,5mm
http://www.club4ag.com/faq_and_tech_pages/Lifter%20Tuning.html
| Back to top |
Uzelac Takumi
Joined: 07 May 2008 Posts: 214 Location: Zemun, Srbija
Posted: Mon Apr 20, 2009 11:27 pm Post subject: |
How do you get to know which height of Yaris shims do you need ?
| Back to top |
gon Takumi
Posted: Tue Apr 21, 2009 12:32 am Post subject: |
there is a table on the website that can give you a guidance.
the numbers in front of the part number are the thickness of the shims.
U can set your clearances right using the standard shims and then using a micrometer measure the shim and the bucket together.
Then order the one that has the same dimension from the table on the website.
or you can buy 8 of the smaller ones and measure your clearances then order the correct ones ....
| Back to top |
Uzelac Takumi
Posted: Tue Apr 21, 2009 1:48 am Post subject: |
As i thought so, nothing before buying new cams and measuring with them .
Thanks!
| Back to top |
Posted: Tue Apr 21, 2009 11:14 am Post subject: |
Thanks for all the answers.
Yes, I mean the Yaris 1,0 bucket, can't remember the engine code.
These cars with 10,5mm lift, how high are they reving?
They guy I bought my modifyed head from, has used it for rally and he just uses stock followers and shims. The cams were 288 degrees duration with about 8,0mm lift.
Cars I have owned:
| Back to top |
gon Takumi
Posted: Tue Apr 21, 2009 11:24 am Post subject: |
under 8.5mm lift stock followers and shims are ok ....
Bruno's car is doing arround 9.5k (10.5mm lift)
apardal one is 8.7k (9.4 mm lift)
mine is 8.7k too but i still have the STD shims and buckets ... my cams only go to 8.5mm lift
| Back to top |
robokill Bunta
Joined: 07 Sep 2004 Posts: 2604 Location: Amsterdam // The Netherlands
Posted: Tue Apr 21, 2009 12:02 pm Post subject: |
you can go to about 9.5mm lift on standard shims (Billzilla's engine did that on standard shims) min is running normal limiter with 9.0mm lift and 8.5mm lift and it goes fine. Don't make a high rev engine doesn't give shit. Better take no more duration than 288 and with like 11mm lift.
Creates loads more power.
_________________ "08 Honda Civic Hybrid
"84 AE86 Zenki Blue Levin (project racer) http://www.cardomain.com/ride/613398
KIS it
Keep It Sideways
| Back to top |
Posted: Tue Apr 21, 2009 12:27 pm Post subject: |
I can see the TRD N2 uses 304' with 10,0mm lift on the intake and 272' 288' 300' and 304' with 10mm lift on the exhaust.
I think I will go for a set of 304' 10mm lift on both intake and exhaust. I know one who use the same setup on his smallport and it produce about 200hp @ crank at only 9000rpm.
I don't wanna build a really high revving engine, as the revs will kill it in a few time. Otherwise, I could buy the old Atlantic engine I was offered, but I dont wanna rebuild it every 2500km and it for sure not good for the street. The price is also a bit too much
Cars I have owned:
| Back to top |
Uzelac Takumi
Posted: Mon May 11, 2009 1:57 am Post subject: |
What springs beside HKS and TODA ? And of course TRD which I can't even goo look how much they cost .
Are HKS good for 10mm lift ?
What about stories that some Supra/Celica valves can be used ?
Does anyone know what diameter/lenght/rate TODA/TRD/HKS valve springs are and help search for alternative solution ?
Thanks
| Back to top |
Bean Bandit Takumi
Joined: 23 Jul 2006 Posts: 422 Location: Brussel/Belgium
Posted: Wed Jul 08, 2009 4:04 pm Post subject: |
catcams.be (use IE doesn't work properly with Firefox or others) do springs as well ~8 Euro per spring (E99862 good for up to 11.5mm lift)
_________________
| Back to top |
