  Home    shopshop    Garage  Forum RSS feed of our forumsForum RSS   FAQ   Search  Memberlist   Register    Log in
Under shim bucket kit qustion
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Technical
Author Message
Jimmi The Kid
Iketani
PostPosted: Mon Apr 20, 2009 9:39 pm    Post subject: Under shim bucket kit qustion Reply with quote
Hi guys
I'm building my AE86 for grip race and will try to get almost the same engine spec as the N2 car.
I allready got some really nice parts, like TRD Atlantic con rods, a highly modified smallport head (yes I know N2 uses bigport head, but this one was cheap), TODA 4-2-1 header, ITB's and so on.
But I wonder about the valve train and springs, as I will run with a highlift cam, 10-11mm and mayby up to 9500rpm.
TODA have a full under bucket shim kit including springs, but it is very very expensive, and I cant find some adjustment shims for it. That is ofcouse really nesesary.
They also have some normally upratet springs, but are these the same springs as in the under bucket shim kit?
If they are the same springs, mayby I could use them together with the 2NZ buckets, as I can get them on my work.
Have anybody tryed this setup with results?????????? Smile
_________________
AE86 newbie - but 20v oldie...
Project AE86 now begun.
Cars I have owned:
Toyota Starlet EP91 1,3 16v
Toyota Starlet EP71 1,3 12v Sport
Mercedes 207D camper, 1977.
Toyota Starlet EP70 with a 174hp Silvertop 20v See video here:
http://videos.streetfire.net/search/Starlet/0/4...-984601079edc.htm
Toyota Corolla AE101 with a 164hp Silvertop 20v. (Evolution bodykit and candycolor paint).
Volvo 240 2,1 (The only car I have maked money on).
Toyota Corolla EE90 (my first car)
Back to top
View user's profile Send private message Send e-mail
totta Crolla
Takumi
PostPosted: Mon Apr 20, 2009 10:07 pm    Post subject: Reply with quote
I'm using 9.5mm lift cams with HKS springs with followers (buckets) from here:
http://www.arrowprecision.co.uk/shims_stock.php
They also do top hat shims to suit and they are available in 16 off or 100 off. I thought they were real expensive but then I realised I was looking at buying 100 of 'em !
Works fine with the cams / springs and a good price too.
_________________
"accidents are rare but you're a long time dead"
Back to top
tolisspi
Bunta
PostPosted: Mon Apr 20, 2009 10:12 pm    Post subject: Reply with quote
You can use the 1szfe of yaris for underbucket shims(maybe the are of 2szfe, i dont know)
I have use them with the toda 's valve springs for 10,5 lift camshafts w/o problem.
I think the valve springs of toda nad the valve spring of the kit are the same. But you can send an email to toda for your question.
Good luck for your project but i wd like more info about your ecu ect
_________________
**COROLLA EE80 - 4AGE 124HP**
Back to top
gon
Takumi
PostPosted: Mon Apr 20, 2009 10:17 pm    Post subject: Reply with quote
don't know about running more than 9,5 10mm of lift without really good valve seats and springs .....
but back to the underbucket shims
just get the yaris ones .
i know 2 cars running them without a prob.
one is running 9,5mm the other 10,5mm
http://www.club4ag.com/faq_and_tech_pages/Lifter%20Tuning.html
Back to top
Uzelac
Takumi
PostPosted: Mon Apr 20, 2009 11:27 pm    Post subject: Reply with quote
How do you get to know which height of Yaris shims do you need ?
Back to top
gon
Takumi
PostPosted: Tue Apr 21, 2009 12:32 am    Post subject: Reply with quote
there is a table on the website that can give you a guidance.
the numbers in front of the part number are the thickness of the shims.
U can set your clearances right using the standard shims and then using a micrometer measure the shim and the bucket together.
Then order the one that has the same dimension from the table on the website.
or you can buy 8 of the smaller ones and measure your clearances then order the correct ones ....
Back to top
Uzelac
Takumi
PostPosted: Tue Apr 21, 2009 1:48 am    Post subject: Reply with quote
As i thought so, nothing before buying new cams and measuring with them Smile.
Thanks!
Back to top
Jimmi The Kid
Iketani
PostPosted: Tue Apr 21, 2009 11:14 am    Post subject: Reply with quote
Thanks for all the answers.
Yes, I mean the Yaris 1,0 bucket, can't remember the engine code.
These cars with 10,5mm lift, how high are they reving?
They guy I bought my modifyed head from, has used it for rally and he just uses stock followers and shims. The cams were 288 degrees duration with about 8,0mm lift.
_________________
Cars I have owned:
Back to top
gon
Takumi
PostPosted: Tue Apr 21, 2009 11:24 am    Post subject: Reply with quote
under 8.5mm lift stock followers and shims are ok ....
Bruno's car is doing arround 9.5k (10.5mm lift)
apardal one is 8.7k (9.4 mm lift)
mine is 8.7k too but i still have the STD shims and buckets ... my cams only go to 8.5mm lift
Back to top
robokill
Bunta
PostPosted: Tue Apr 21, 2009 12:02 pm    Post subject: Reply with quote
you can go to about 9.5mm lift on standard shims (Billzilla's engine did that on standard shims) min is running normal limiter with 9.0mm lift and 8.5mm lift and it goes fine. Don't make a high rev engine doesn't give shit. Better take no more duration than 288 and with like 11mm lift.
Creates loads more power.
_________________
"08 Honda Civic Hybrid
"84 AE86 Zenki Blue Levin (project racer) http://www.cardomain.com/ride/613398
KIS it
Keep It Sideways
Back to top
Jimmi The Kid
Iketani
PostPosted: Tue Apr 21, 2009 12:27 pm    Post subject: Reply with quote
I can see the TRD N2 uses 304' with 10,0mm lift on the intake and 272' 288' 300' and 304' with 10mm lift on the exhaust.
I think I will go for a set of 304' 10mm lift on both intake and exhaust. I know one who use the same setup on his smallport and it produce about 200hp @ crank at only 9000rpm.
I don't wanna build a really high revving engine, as the revs will kill it in a few time. Otherwise, I could buy the old Atlantic engine I was offered, but I dont wanna rebuild it every 2500km and it for sure not good for the street. The price is also a bit too much Wink
_________________
Cars I have owned:
Back to top
Uzelac
Takumi
PostPosted: Mon May 11, 2009 1:57 am    Post subject: Reply with quote
What springs beside HKS and TODA ? And of course TRD which I can't even goo look how much they cost Smile.
Are HKS good for 10mm lift ?
What about stories that some Supra/Celica valves can be used ?
Does anyone know what diameter/lenght/rate TODA/TRD/HKS valve springs are and help search for alternative solution ?
Thanks
Back to top
Bean Bandit
Takumi
PostPosted: Wed Jul 08, 2009 4:04 pm    Post subject: Reply with quote
catcams.be (use IE doesn't work properly with Firefox or others) do springs as well ~8 Euro per spring (E99862 good for up to 11.5mm lift)
_________________
Back to top
View user's profile Send private message Visit poster's website MSN Messenger
Display posts from previous:
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Technical All times are GMT + 2 Hours
Page 1 of 1
Jump to:
