a lil help :D
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Drifters
Author Message
FCEE
Itsuki
PostPosted: Sun Jan 28, 2007 1:18 am    Post subject: a lil help :D Reply with quote
hey guys well i finally sold my fc and bought me a 86 hatch sr5 and yea i juss wanted to knoe what a good setup would be for daily driving / drift for my hachi 1st time owner so juss wanna do it right . any advice would help thx
_________________
I WANT TO TRADE MY 90 FC 124 K ON IT WELL MAINTAINED. HKS INTAKE XIO DUAL EXHAUST MAGNA FLOW CAT , SPORT FUEL FILTER , SHORT SHIFTER , TCS SWAY FRNT AND BACK , DRIFT BODY KIT , TII CARBON FIBER HOOD a shit load of other mods. really want to trade not a hard person to talk to so yea get at me man cuz heres the link to the pic ill post more once i get ma homies camera
------> http://i5.photobucket.com/albums/y184/swtguyxdihn/FC3S.jpg thx guys
Back to top
View user's profile Send private message Send e-mail AIM Address
evfan42
Ryousuke
1986 Toyota Corolla AE86 (late US)
PostPosted: Sun Jan 28, 2007 8:12 am    Post subject: Reply with quote
Well, to let you know, the sr5 version of the hatchi doesn't have a limited slip diff. Only the GTS came with that. Also the engine is quite underpowered at about 60-70 hp.
This is what I am doing, I bought a 4AGE 20v silvertop (from AE101.) And I am going to put it in, with quite a few mods, etc. to raise the power, later I will find a GTS axle to put into the car. Thats just a few things I will do to mine, I could write a story of what I'm planning to do but whatever you want to do could be completly different.
For the engine you could find a 4AGE from a GTS 86 to drop in. I've even seen 86's with rotary. its your choice.
so to make a long post short, find what you want to do, then do it. Puh
main points for drift, drivetrain, suspension, engine, and anything else im sure the experts will correct me on. Wink
Back to top
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger MSN Messenger
evfan42
Ryousuke
PostPosted: Sun Jan 28, 2007 8:13 am    Post subject: Reply with quote
Oh yeah, and dont forget to post your project on the site Puh
Back to top
Mux213
Site Admin
PostPosted: Sun Jan 28, 2007 12:43 pm    Post subject: Reply with quote
FCEE,
There has been a lot of discussion about suspension in the technical forum so you best start reading there. This thread has alot of info:
http://www.aeu86.org/viewtopic/ksport-what-abou...vers-cheap/t/4219
This one as well:
http://www.aeu86.org/viewtopic/ae86/t/983
Also check out the Tech FAQ on the front page about suspensions:
http://www.aeu86.org/index/ae86/cat/9/topic=4146/post=58122
And as evfan mentioned, you have an SR5 so you'll need to find a GTS rear axle so you have LSD or can install a better 2way LSD. There isn't one available for the SR5 axle.
Last but not least, get better engine:D Also loads of threads on the forum about swapping engines.
_________________
No more hachi Sad
Back to top
NZ Trueno
Wataru
PostPosted: Thu Feb 08, 2007 3:55 am    Post subject: Reply with quote
Im in a slightly different boat with my ae85 (even lower standard than sr5 Blonde question ) but i found this write up very useful:
http://forums.toyspeed.org.nz/viewtopic.php?t=46779
Hope you don't mind me linking to another site's thread...
Back to top
Mux213
Site Admin
PostPosted: Thu Feb 08, 2007 9:17 am    Post subject: Reply with quote
Owh nice thread!
No, I see no problem in linking to other sites. We're all one big happy family:D
_________________
No more hachi Sad
Back to top
NZ Trueno
Wataru
PostPosted: Thu Feb 08, 2007 11:25 am    Post subject: Reply with quote
Good, i didnt want to get in trouble! Puh
Doing the swap from the 4ac is basically the same as from 3au; they are both patheticly slow carbied engines.
Back to top
dr.occa
Wataru
PostPosted: Fri Feb 09, 2007 11:51 pm    Post subject: Reply with quote
first things first, if you can find a gts rear end w/ lsd you're half way there. and be sure to grab the driveshaft with it as well. if not, see about getting your sr5 diff welded. it'll be better than nothing. as for the weaker 4ac carbed engine, it may still be ok for at least getting you use to the the feel of the car. it's possible the car may bog when in mid drift (after you've gotten an lsd or welded diff of course!) due to the factory carb. but get yourself into a better differential situation and THEN try drifting. Thumbsup
_________________
Back to top
View user's profile Send private message Visit poster's website AIM Address
FCEE
Itsuki
PostPosted: Sun Feb 18, 2007 4:34 am    Post subject: Reply with quote
cool thanks guys well yea the cars running fine sr5's a monster lol still running i mean by that i juss recently put sea foam in it its bo0ty full wit sum royal purple oil everythings coo juss saving money for a 4agze motor but since the 4agze is mr will it take a lot of fabrications ? any ADVICE ON A GOOD ENGINE FOR MY 86 . ANY SUGGESTIONS OF WHAT TYPE AND WHERE I CAN ORDER IT
_________________
Back to top
Mux213
Site Admin
PostPosted: Sun Feb 18, 2007 11:37 am    Post subject: Reply with quote
FCEE,
Shouldn't you change your sig ?Very Happy
The 4AGZE mates with the T50 tranny in your SR5 and the tranny should be the same as in the GTS so should hold up unless you go crazy on the HP. Also engine mounting points you should be able to mix and match some things with the old engine (allthough thats mostly what I remember reading about a GTS -> 4AGZE swap so not fully sure about the SR5).
Your main problem will be all the bits around the engine, fuel system, intercooler piping, that sorta thing. The technical document section on club4ag should still be up and running and contains a good document about the GTS to AGZE swap.
There is also a good document there about other engine choices.
_________________
No more hachi Sad
Back to top
Display posts from previous:
Post new topic   Reply to topic    [AEU86] EU AE86 community Forum Index -> AE86 : Drifters All times are GMT + 2 Hours
Page 1 of 1
Jump to:
You cannot attach files in this forum
