  Home    shopshop    Garage  Forum RSS feed of our forumsForum RSS   FAQ   Search  Memberlist   Register    Log in
Home » AE86 specifications
Menu
Technical FAQ
Wallpapers
AE86 for sale
Events
Links
Donations
RSS
Contact
How to
Axle & differential
Bodywork
Brakes
Engine
Gearbox
Interior
Suspension
Technical
AE86 Colorcodes
AE86 JDM Parts
AE86 Manuals
AE86 specifications
Corolla production data
Toyota color codes
Toyota differentials
Toyota Engine codes
Toyota EPC manual
Toyota Firewall ID codes
AE86 specifications
Tue Apr 10, 2007 11:16 pm by Apolan
1983-1987 Toyota Corolla Trueno/Levin AE86 specifications:
BODYWORK
Code: AE86
Type: 2+2 (coupe/hatchback)
Number of doors: 2 (coupe), 3 (hatchback)
DIMENSIONS & WEIGHT
Wheelbase: 2400 mm
Track width: front_ 1355 mm, rear_ 1345 mm
Length: 4285 mm
Width: 1625 mm
Height: 1335 mm
Kerb weight: 950 kg (coupe), 970 kg (hatchback)
Weight distribution: 53:47 (%) front:rear
Fuel capacity: 50 litres
AERODYNAMICS
Drag coefficient: 0.35
ENGINE
Code: 4A-GE(U/C/L)
Type: Inline 4, wet sumped, DOHC, 16 valves (4/cylinder), fuel injected, normally aspired, water cooled, T-VIS large-port
Bore x stroke: 81.00 x 77.00 mm
Bore / stroke ratio: 1.05
Displacement: 1587 ccm
Unitary displacement: 396.75 ccm/cylinder
Compression ratio: 9.4:1 or 10.2:1
Max power: 91 kW (124 hp) @ 6600 rpm
Max torque: 145 Nm @ 5200 rpm
Max engine speed: 7700 rpm
Specific output: 78 hp/litre
Specific torque: 91 Nm/litre
CHASSIS
Engine location: front
Engine alignment: longitudinal
Steering: rack & pinion
Suspension: FRONT_ MacPhaerson strut & coil spring & sway bar, REAR_ multilink & coil spring & sway bar (solid axle)
Wheels: 5.5x13" or 5.5x14" or 6x14"
Tyres: 185/70 HR13 or 185/60 HR14
Brakes: front_ vented discs 234 mm, rear_ discs 231 mm (servo asisted)
TRANSMISSION
Code: T50
Type: 5-speed manual
GEAR RATIOS:
1st: 3.587
2nd: 2.022
3rd: 1.384
4th: 1.00
5th: 0.861
Reverse: 3.48
Final Drive: 4:30:1
Clutch-Type LSD
PERFORMANCE
0-100 km/h: 8.5 s
1/4 mile: 16 s
Top speed: 200 km/h
Power to weight ratio: 130 hp/tone
Production dates
Zenki: From Aug. 1983 to Jul. 1985
Kouki From Aug. 1985 to Jul. 1987
[AEU86] EU AE86 community Forum Index
