AE86 Lower engine mounts
10-26-2009, 07:28 PM
Can someone tell me who makes the lower engine mounts for AE86 and what happens with the gearbox mount? I am after engine and gearbox mounts aswell.
Cheers!
10-26-2009, 08:11 PM
There are some japanese manufacturers who build those.
Will go down 20mm.
I think they also sell mounts for the gearbox but in the end it does not matter that much since the driveaxle will take the added angle.
Speed Industries
Hurdnerwaeldlistr. 73
8808 Pfaeffikon
Switzerland
e-mail: [email protected]
phone: +4155 420 15 69
page: http://www.speed-industries.ch
MSN: [email protected]
We have all the parts your Hachi needs
10-26-2009, 10:46 PM
TRD do upgraded engine mounts, the gearbox mount is still OEM.
[Image: m829ice_doll-img600x450-1256901300jrvqff47395.jpg]
http://store.autosportsupplies.com/merch...0Mount.jpg
Cusco make stiffer engine and gearbox mounts. (about 10mm lower?)
[Image: enginemountshk7.jpg]
Techno Pro Spirits offer mounts that lower engine 10mm.
[Image: engine.jpg]
Tec-Arts 20mm lower metal mount that goes on the cross member.
[Image: A23_Z1.jpg]
*Picture is SP-Tec item - pretty much identical to Tec-Arts
[Image: 86LIFE.gif]
RokuSteady : Shakotan - Tsuraichi - Hippari - Onikyan : 神奈川 様式
10-27-2009, 07:11 AM
Thanks for the responses. Thumbs up!
10-28-2011, 08:08 AM
Does anyone know when they make lower mounts do that just make the rubber shorter, or do they have to offset the angle of the bolts as well since the mount sits on an angle?
10-28-2011, 02:34 PM
4000GT Wrote:Does anyone know when they make lower mounts do that just make the rubber shorter, or do they have to offset the angle of the bolts as well since the mount sits on an angle?
By theory I'd say they offset the bolts slightly - I have the cuscos mounted on my car but didn't take any measurements, I got a picture in my projecthread - so if someone can take a picture of the OEM items at the same angle, this would let us compare.
As I see it a combo of cusco rubber mounts and SP-Tec metal mounts would give you 30mm lower engine although one would need to makes sure then to keep the sump safe and enough clearance to crossmember.
[Image: DWsig.jpg]
  AE86 registration troubles wheels/engine/ect. Ryo 6 2,350 10-18-2010 07:22 PM
Last Post: ZDoman
  New to ae86 need help with engine rebuild Snafu415 2 1,254 06-27-2009 04:16 PM
Last Post: GWtaylor
