ring gear bolts
12-24-2016, 06:17 PM
ring gear bolts
building the axle right now. can i reuse the ring gear bolts? if not, which bolts do i need to buy?
12-24-2016, 10:22 PM
ring gear bolts
I have re-used them without issue, you might want to use new locking tabs though.
An analogue brain in a digital World |
12-25-2016, 02:32 PM
ring gear bolts
thanks, with the kaaz diff i cant use the locking tabs. do you think i can use a little loctite?
12-26-2016, 10:56 PM
ring gear bolts
Yes genuine Loctite will work. Check the application as there are different grades of Loctite.
5th gear issue | r.ave | 1 | 2,190 |
03-14-2021 08:52 PM Last Post: Ivan141 |
Head bolts: You decide..... | oldeskewltoy | 8 | 8,624 |
11-11-2020 06:33 PM Last Post: oldeskewltoy |
T50 gearbox - TRD 2nd and 3rd gear | hachirokkos | 3 | 6,045 |
11-27-2015 10:06 AM Last Post: Project D |
torque setting head cylinder bolts | izanagi | 1 | 4,452 |
05-29-2015 01:23 AM Last Post: oldeskewltoy |
Decently heavy vibration in fourth gear between 2000-2300rpm | dinkers542 | 4 | 5,052 |
11-29-2014 12:27 AM Last Post: dinkers542 |
