T50 gearbox - TRD 2nd and 3rd gear
11-26-2015, 01:47 AM
Does anyone know, if i can replace my 2nd and 3rd gears only withthe TRD gears and counter gears only ? Is this possible, and i will have 1,4 and 5 stock but 2nd and 3rd TRD
Sent from my SM-G900F using Tapatalk |
11-26-2015, 01:32 PM
No you can't. You will not be able to fit the gears on the OEM counter shaft since it's a solid piece from 1 through 3 (or 4, depending on how you look at it)
That's why ALL gearset sold for the T50 includes a specific counter shaft. |
11-27-2015, 09:16 AM
(This post was last modified: 11-27-2015 09:17 AM by hachirokkos.)
(11-26-2015 01:32 PM)Project D Wrote: No you can't. You will not be able to fit the gears on the OEM counter shaft since it's a solid piece from 1 through 3 (or 4, depending on how you look at it) Thanks for the info mate. Do you have any1 in mind that might sell an T50 gearbox with the trd set A inside ? Also what about REVOLVER gear sets or KDX ? Where can i purchase them ? I know about cusco but i trying to find some other solutions to compare |
11-27-2015, 10:06 AM
The TRD set A (A851) as been discontinued for years and the chance to find a used set in good condition is pretty low.
(plus it did not solve the huge gap between the 3 and 4, so doesn't worth it IMO) For the KDX it's even worse, discontinued for at least a decade (the company doesn't even exist anymore) Revolver; as far as I know they are still in production so you can buy them new. Ask shops like RHD, nengun, Perfectrun etc.. if they can get it for you. TTS have a set available MHM too. |
Gearbox mount and transmission mount | gh0st | 9 | 2,682 |
05-08-2022 03:28 PM Last Post: totta Crolla |
T50 gearbox | totta Crolla | 3 | 1,830 |
02-25-2022 02:35 PM Last Post: Project D |
5th gear issue | r.ave | 1 | 2,220 |
03-14-2021 08:52 PM Last Post: Ivan141 |
T50 TRD gearset | DidiDex | 7 | 7,691 |
09-12-2019 07:36 PM Last Post: DidiDex |
Shifting from 4th to 3rd | pack | 7 | 5,393 |
04-27-2017 07:26 PM Last Post: totta Crolla |
