torque setting head cylinder bolts
05-28-2015, 05:04 PM
Hi all,
I would like to change the head gasket of my AE92 4AGE TVIS Red Top (early 88-89 Big Port) engine. I saw in the manual that the torque setting for the head cylinder bolt is (29 Nm + 90° + 90°) but I saw on internet that exists a new manual with the setting (60 Nm + 90° + 90°), it makes a big difference. What is correct ? Thanks for your help Kevin |
05-29-2015, 01:23 AM
(05-28-2015 05:04 PM)izanagi Wrote: Hi all, Were the specifications from a factory service manual update?? Where did you get this information?? Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
4AGE cylinder head plug removal | Ivan141 | 5 | 1,075 |
09-30-2023 09:47 PM Last Post: Ivan141 |
Head bolts: You decide..... | oldeskewltoy | 8 | 8,627 |
11-11-2020 06:33 PM Last Post: oldeskewltoy |
Brake advice - master cylinder | mannix20vt | 12 | 12,556 |
08-21-2017 03:21 PM Last Post: Project D |
Torque settings | kazi | 4 | 5,312 |
03-28-2017 12:15 AM Last Post: kazi |
ring gear bolts | DJexor | 3 | 4,846 |
12-26-2016 10:56 PM Last Post: totta Crolla |
