wiring aftermarket tachomete
05-19-2014, 05:43 PM
Hi all,
I would like to add an aftermarket tachometer to my AE86 but I don't know if it's possible and how to wiring that. Thanks for your help. |
05-19-2014, 08:18 PM
It should be perfectly possible as long as you have a tacho that is suitable for a four cylinder car.
You can look up which wire to pick up from the combination meter in the wiring diagram manuals (EU or USDM) or the body repair manual (page BE-22): http://www.aeu86.org/technical/ae86-manuals/ Or you draw a new line from the coil directly and fuse it properly. I think last month's edition of Practical Classics had a nice how-to on the whole subject. I'll have a look if I can scan that article. 1982 - TA60 Carina 4dr sedan - fun cruiser 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
05-19-2014, 10:39 PM
(05-19-2014 08:18 PM)banpei Wrote: It should be perfectly possible as long as you have a tacho that is suitable for a four cylinder car.Perfect. Thank you mate. |
05-20-2014, 09:18 AM
This morning I scanned the article and added it as an attachment.
Hope this helps you out. 1982 - TA60 Carina 4dr sedan - fun cruiser 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
05-21-2014, 02:38 AM
Generally speaking, most decent aftermarket tacho's can accept
5V square wave, 12V square wave or voltage spike inputs. If you take the signal directly from the coil, you need a tacho that can accept a voltage spike input, so check the tacho data sheet. Square wave outputs are found on later model cars, and originate from the ECU or igniter module. Cheers... jondee86 |
05-21-2014, 07:03 AM
(This post was last modified: 05-21-2014 07:06 AM by izanagi.)
Thanks for the help. I will check before buying.
Envoyé depuis mon GT-I9100 avec Tapatalk (05-21-2014 02:38 AM)jondee86 Wrote: Generally speaking, most decent aftermarket tacho's can accept Any brand that it's sure it works to advice me ? Thanks Envoyé depuis mon GT-I9100 avec Tapatalk |
05-21-2014, 08:28 AM
Hard to go wrong with VDO
05-21-2014, 08:15 PM
(05-21-2014 02:38 AM)jondee86 Wrote: Generally speaking, most decent aftermarket tacho's can acceptI stand corrected here. 1982 - TA60 Carina 4dr sedan - fun cruiser 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
Tail light wiring... | Mylesmck | 4 | 339 |
02-02-2024 12:36 PM Last Post: Mylesmck |
Lambda sensor wiring | sam3007 | 10 | 3,296 |
05-23-2022 10:00 PM Last Post: The Doctor |
4A-GE wiring engine to chassis connectors | Lykowsky | 4 | 6,317 |
06-20-2019 11:38 AM Last Post: Lykowsky |
Some wiring help needed | DJexor | 5 | 4,824 |
05-18-2019 01:50 PM Last Post: DJexor |
AE86 Headlight + wiper wiring (levin) | bozu | 11 | 14,243 |
09-19-2017 02:06 PM Last Post: banpei |
