HKS valve springs
05-13-2022, 06:20 PM
HKS valve springs
Can anyone tell me the safe lift limit of HKS blue/white 16v
valve springs? An analogue brain in a digital World |
05-14-2022, 02:37 AM
HKS valve springs
They are designed for their 8.1mm lift camshaft.
From memory they got a little bit more compression height before coil bind, but not so much so that you could fit some super agressive cams. They may be good for ~9mm lift, but I wouldn't push my luck past that. |
05-14-2022, 08:30 PM
HKS valve springs
Thanks for confirming.
05-25-2022, 10:24 PM
HKS valve springs
https://www.club4ag.com/forums/viewtopic...3&start=30
"HKS - 30#s @ 34.7mm(1.366"), full bind comes in @ .415", subtract .050" and you are left with .365" before "effective coil bind". Pressure @ "effective coil bind - 120#s" Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
4AGE Valve Buckets Scored | Steller Engineering | 2 | 489 |
20 Valve Blacktop smoking after engine flush - why? | RolanTHUNDER | 2 | 850 |
HKS Legal exhaust | Nakilad | 2 | 4,070 |
07-31-2019 10:00 AM Last Post: Nakilad |
HKS 260 8.0 Cam Card | d3nso | 5 | 6,278 |
02-14-2018 08:29 PM Last Post: oldeskewltoy |
Anyone farmiliar with hks camshaft types for 4age? | spill86 | 5 | 14,063 |
11-18-2017 11:36 PM Last Post: oldeskewltoy |
