TOYOTA COROLLA Ke70 - Restoration project
08-31-2013, 12:19 PM
I don't know if this is the right section to start this topic, but here goes.
As promissed, here goes some actual pics of my KE70, and all restoration project! It´s a 83' KE70, with a lot of rust.... It all began in 2010, when i sold my previous Ke70 liftback and I regretted having sold the car, because it was my dad's car, and he had it for 19 years, but the car needed some work to be roadworthy. Then, in 2011, i began the search for a "new" ke70, and this time it had to be a sedan, because i wanted to create something looking like the Japs MotorFix KE70. So, in September in the same year, i found this one, it was very rusty, but it had to be this one, because it was the only one that i found for sale. The day when it came home The rust that can be seen..lol Jorda MotorSport Keto Beams Project |
08-31-2013, 12:20 PM
Some pics before going to the shop taking care of that bodywork (full restoration).
As you can see in the pics, i took the fogs out, and replaced the front signal lenses Jorda MotorSport Keto Beams Project |
08-31-2013, 12:23 PM
Some material i´ve bought...
Quad lights. AE86 front struts, which, now, i only have the braking and the hub. (Before) (Now, fully restored) AE86 kouki rear axle and the drive shaft Jorda MotorSport Keto Beams Project |
08-31-2013, 12:25 PM
And now, the beginning...
(80' series front for the quadys) Jorda MotorSport Keto Beams Project |
08-31-2013, 12:26 PM
Current shape of the car...
Some door work Jorda MotorSport Keto Beams Project |
08-31-2013, 12:27 PM
The front passenger door is now 90% restored, it still needed to close the door skin. The other door (rear passenger), is going to give more work to the man, because it is in shit condition
Here goes some pics (the shitty door) Jorda MotorSport Keto Beams Project |
08-31-2013, 12:30 PM
Now all the doors are fully restored, and waiting for the rest of the car to be completed.
I've also acquired a 4AGE with twin Dellortos + T50 gearbox, i am now rebuilding the engine. So here goes the update: The doors ready ...As well as the front fenders The workshop guy started to work in the chassis, removing that rusty corner inside the wheel arch The master doing the work The mold being welded... ...And now ready Pillar C being worked Adding and preparing the molds Jorda MotorSport Keto Beams Project |
08-31-2013, 12:31 PM
And now some parts i've bought to the car
Vitaloni California mirrors (the same used by motorfix) and some pedal caps, TRD horn Button, Stainless steel brake lines, Ferodo 5.1 braking oil, door seals, steering wheel hub, tail lights, early models bumpers, and a new door to the rear, because the other one would give a lot of work... And NOW the engine, and the rebuild of it which will be featured later on Mechanical distributor will be using to this setup Jorda MotorSport Keto Beams Project |
08-31-2013, 12:35 PM
The beginning of the rebuild.
Still with the cams Lots of coal to remove Without cams Finally i've separated the engine head of the block, and this was the scenario: Piston nº1 Piston nº2 Piston nº3 Piston nº4 The head was not so different ...to be continued Jorda MotorSport Keto Beams Project |
Toyota Corolla AE86 LEVIN ( Poland) | sylwekgtir | 40 | 50,397 |
Full restoration... | Blade1988 | 64 | 79,738 |
07-17-2016 11:53 AM Last Post: McGlinchey |
Another danish restoration | Duze | 61 | 66,209 |
03-20-2016 08:58 AM Last Post: Duze |
'84 ae86 restoration project | HybriD07 | 19 | 23,414 |
10-13-2014 09:20 PM Last Post: HybriD07 |
Black Limited restoration | slpery86 | 6 | 9,176 |
12-17-2013 09:22 PM Last Post: banpei |
