McKenney's 1UZFE Kouki Levin Coupe
03-12-2013, 04:48 AM
So basic rundown:
1987 USDM Corolla GTS 1987 Kouki JDM Levin front end MR2 manual rack with AE86 power steering tie rods power steering knuckles Hondarue BigBrake adapter kit FC3S front calipers and pads Mini Cooper S rotors redrilled for AE86 hubs NEW stock rear calipers, pads, and rotors OEM Toyota ebrake cables P.A.S.S. Racing front coilovers Bilstein shocks and strut cartridges Swift springs 9.5kg front, 6.5kg rear T3 panhard rod for Celica Supra 7.5" diff Celica Supra 7.5" diff w/ 3.91 gears MK3 W58 w/ MK2 striker arm and shifter base Soarer shifter Exedy Stage 2 clutch for 1995 4runner/Hilux Surf w/ 3vze 1992 SC400 1UZFE w/ LS400 oil pan and pickup Hondarue EGR delete plates Xcessive manufacturing 1UZFE/W58 into AE86 brackets and crossmember 1uzfeswapkits.com trans adapter and flywheel kit w/ internal slave cylinder and braided lines S13 brake master cylinder Hondarue booster delete plate Hondarue 2" subframe spacers 1987 Landcruiser clutch master cylinder (3/4") bore Scirocco aluminum radiator New front LCAs stock GTS front sway bar OEM tension rods Cusco RCAs And for some eye candy: newtoy4 by McKenneyLevin, on Flickr 030112151100 by McKenneyLevin, on Flickr spacerfinal by McKenneyLevin, on Flickr Untitled by McKenneyLevin, on Flickr Untitled by McKenneyLevin, on Flickr Untitled by McKenneyLevin, on Flickr Untitled by McKenneyLevin, on Flickr Untitled by McKenneyLevin, on Flickr Untitled by McKenneyLevin, on Flickr Untitled by McKenneyLevin, on Flickr Untitled by McKenneyLevin, on Flickr Untitled by McKenneyLevin, on Flickr Untitled by McKenneyLevin, on Flickr Untitled by McKenneyLevin, on Flickr Untitled by McKenneyLevin, on Flickr Untitled by McKenneyLevin, on Flickr Untitled by McKenneyLevin, on Flickr |
03-12-2013, 04:53 AM
I have a full build on 86garage.com. you'll have to register and make an introduction to view the full site. My build thread is located here after you've registed:http://www.86garage.com/forums/viewtopic.php?f=42&t=4997
There's a lot of trial and error in the build thread, and 15 pages of it too. I gave aeu86.org the abridged version lol. Hope you enjoy the read and the pics. |
Trueno Hatch and Levin Coupe - Repair, replace, pray xD | TomRich | 13 | 13,147 |
@dodo@ Levin Coupe, renovation and tuning (56k think twice) | @dodo@ | 165 | 148,870 |
Aram's 3SGE Beams Levin Coupe | robokill | 665 | 688,622 |
Matt's "Drives as fast as it's Towed" 85 Levin Coupe | mad.matt | 38 | 37,147 |
04-07-2016 12:15 PM Last Post: mad.matt |
DidiDex 1984 Levin coupe rebuild | DidiDex | 1 | 4,973 |
08-13-2015 03:22 PM Last Post: DidiDex |
