Oil plug thread size is M18x1.5 ????
06-07-2012, 11:36 AM
I guess title is clear.
Thanks already |
06-07-2012, 04:02 PM
Toyota = M12 X P1.25 for the oil pan drain bolt.
06-07-2012, 04:36 PM
Really??
It looks way bigger. Spanner size is Hex 19. Maybe later Engines used hex 14 which might be M12 Mine is an '84 model |
06-07-2012, 04:45 PM
You're talking about the engine oil drain plug, right ?
I never seen any Toyota with anything other than m12x1.25. From a KE70 to a supra mk4, they all have the same plug... So, if your plug is different, then it have been modified... |
06-07-2012, 04:54 PM
Indeed it's the engine oil plug.
It should be standard still on my car. So it's M12 ... Anyway, I will consider making an early oil change to check the size to be sure... :wink: Thanks |
4AGE cylinder head plug removal | Ivan141 | 5 | 1,190 |
Plug ID | kazi | 6 | 5,715 |
02-17-2019 10:07 PM Last Post: kazi |
Shim size for AM cams | kazi | 4 | 4,582 |
Hub size | kazi | 5 | 8,619 |
06-09-2017 10:06 PM Last Post: kazi |
16v distributor hole plug | harkes | 8 | 8,611 |
