valve tick on cylender two intake
12-15-2014, 05:52 AM
Post: #31
Just ordered both testers and will run both. When I do the comp test will I want to turn the crank pully as fast as possible?
12-15-2014, 09:52 AM
Post: #32
(12-15-2014 05:52 AM)dinkers542 Wrote: Just ordered both testers and will run both. When I do the comp test will I want to turn the crank pully as fast as possible?the compression tester has a oneway valve so just turn it gradualy a couple of times untill the gauge isn't going substantialy higher anymore. Apart from reaching the minimum spec you'll also want the cylinders to be even (less than 1bar/14psi difference) AE86 ex-daily |
4AGE Valve Buckets Scored | Steller Engineering | 2 | 451 |
20 Valve Blacktop smoking after engine flush - why? | RolanTHUNDER | 2 | 818 |
HKS valve springs | totta Crolla | 3 | 1,578 |
AE86 4age engine not starts crank ok backfires to air intake | Ryo | 18 | 15,086 |
08-16-2018 01:36 AM Last Post: Bean |
Valve clearance | leon205gti | 7 | 7,916 |
11-25-2016 03:24 AM Last Post: oldeskewltoy |
