intake runner lenght with ITBs discussion
02-20-2010, 02:30 AM
IMHO fitting an airbox (with fresh/outside enginebay air duct) will result in far more better results for cooler intake chare than any insulation between head and manifold...
AE86 ex-daily |
02-20-2010, 07:31 AM
jondee86 Wrote:Jimmi The Kid Wrote:I will place my injectors at the end of the stack - oldschool formula 1 trick... If you look at formula atlantic 4ag's you see they all run secondary injectors infront of the stacks. Obviously cold start isnt an issue, or is drivability in an open wheeler. ust check the overall length, and the offset on cylinders 1 and 4 vs 2 and 3 Brake with the left hand, steer with the right foot... |
02-20-2010, 09:32 AM
mc68 Wrote:Just check the overall length, and the offset on cylinders 1 and 4 vs 2 and 3Been a few bikes using those staggered stacks for a while. It's said to help broaden the torque band. So, like thermal insulators throttlebody spacers and Irridium plugs... every little bit helps Cheers... jondee86 |
02-20-2010, 10:02 AM
And what do you guys thinkabout those type of adaptor inlet manifolds?
http://cgi.ebay.co.uk/Toyota-4AGE-4AG-16...2eaafe5be2 SR Team BURN THE RUBER NOT YOUR SOUL! |
02-20-2010, 11:58 AM
looking at the quality of the piece in the pics IMHO they are not worth it the T3 one is about 50$ more but have a close look at the inlet side in the auction pics you'd need to do quite some adjustments on those as they are 'hand made'
AE86 ex-daily |
02-20-2010, 12:21 PM
mc68 Wrote:If you look at formula atlantic 4ag's you see they all run secondary injectors infront of the stacks. Jup, secondaries are ok, but notice that they also run primary injectors aimed at the valves. A wheel to steer the front of the car A pedal to steer the rear |
03-16-2010, 01:09 PM
Where do I messure the ideal runner diameter? Is it the throttle valve or what does it means?
Project AE86 now begun. Cars I have owned: Toyota Starlet EP91 1,3 16v Turbo, 200hp Toyota Starlet EP71 1,3 12v Sport Mercedes 207D camper, 1977. Toyota Starlet EP70 with a 174hp Silvertop 20v See video here: http://videos.streetfire.net/search/Star...079edc.htm Toyota Corolla AE101 with a 164hp Silvertop 20v. (Evolution bodykit and candycolor paint). Volvo 240 2,1 (The only car I have maked money on). Toyota Corolla EE90 (my first car) |
03-16-2010, 01:31 PM
usualy you take the diameter of the throttleplate unless there is a huge size difference in your runners compared to the throttleplate than you would use an average
AE86 ex-daily |
03-17-2010, 09:39 PM
Thank you. I messured my AE111 ITB's to 45mm, and this should be close to my target
03-27-2010, 07:45 AM
Im presuming you are using a plenum as well? Trumpets alone without a plenum lose a nice amount of mid range power and torque.
Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP | mister86 | 12 | 9,643 |
AE86 4age engine not starts crank ok backfires to air intake | Ryo | 18 | 15,194 |
valve tick on cylender two intake | dinkers542 | 31 | 25,507 |
12-15-2014 09:52 AM Last Post: Bean |
4age blue top from MR2 same intake manifold? | dinkers542 | 8 | 9,756 |
11-02-2014 05:24 PM Last Post: ditn |
4AGE Heat Shielding Intake Gasket | asyrigos | 11 | 22,592 |
04-01-2013 10:58 AM Last Post: asyrigos |
