how to add power to AE86
11-26-2012, 10:16 PM
oldeskewltoy Wrote:lifebeginsat8000rpm Wrote:how can u now u have a high comp version i mean without removing the head istn there a code on the blok or somthing |
11-26-2012, 10:31 PM
lifebeginsat8000rpm Wrote:oldeskewltoy Wrote:lifebeginsat8000rpm Wrote:how can u now u have a high comp version From MY understanding... 1) Singapore, and SOME areas in Europe got the high compression engines. 2) This compression difference seems to correlate to cars with, or without catalysts. Cars/engines without cats... got high comp engines, cars/engines with cats got lower comp engines. 2a) This SEEMS to be the difference between 4AGE and 4AGEC. The "C" meaning catalyst equipped Now for some bad news... these cars are over 25 years old now... there is a fair chance that the original engine is no longer in the car... so knowing if your car was originally cat equipped may not be helpful. Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
11-26-2012, 10:38 PM
oldeskewltoy Wrote:my car has no cat i am from belgium just like the care is bone stock en the first origenel engine no rust no melding almost show room conditions 120dkmlifebeginsat8000rpm Wrote:oldeskewltoy Wrote:lifebeginsat8000rpm Wrote:how can u now u have a high comp version |
11-26-2012, 11:02 PM
This is the piston of my engine,its also an original belgium ae86 i think
but its dirty cause old engine high res http://i45.tinypic.com/2pytljp.jpg http://i46.tinypic.com/343kdo2.jpg |
11-26-2012, 11:09 PM
If it is bone stock and from Belgium it is bound to have the high compression engine.
1982 - TA60 Carina 4dr sedan - fun cruiser 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
11-27-2012, 05:56 AM
Btw.... Im making about 170 crank hp 145 wheel hp using those pistons in my 4AGE
How to add photos to your posts | banpei | 2 | 4,302 |
01-17-2022 10:31 PM Last Post: banpei |
A new Toyota to add to the fleet. | James | 9 | 6,950 |
03-12-2009 12:30 AM Last Post: AZNWOKZ |
HI Power AE86 | GTRJazz | 13 | 18,943 |
10-20-2007 06:48 PM Last Post: TE71corolla |
