ford type 9 gearbox with 4age engine
12-24-2014, 09:25 AM
Did anyone ever make a type 9 or borg warner T-5 to 3sg bellhousing?
Andrew |
12-24-2014, 11:09 AM
(This post was last modified: 12-24-2014 06:41 PM by Uzelac.)
(12-23-2014 01:28 AM)filh Wrote: Uzelac : on Esa Peltonen site :http://www.esapeltonen.fi/ refering to AE86 parts the gearbox is well called Dogbox (3 models). Yes, you are right, i've seen that. What confuses me now is my gearbox. It should be KL, but it is synchomesh with helical gears and I don't see one like that on their website. Hmm ... |
12-25-2014, 11:52 PM
dog box are made with straight cut pinions , Quaife made both straight cut pinions, with dog or synchromesh engagement.
Not many details on Espeltonen site , about gearbox (ratios ? historical version?). The advantage : it's a direct bolt on . I guess it would be better to email him . Phil Filh Save the RWD cars |
12-26-2014, 12:26 AM
better pics of Toyota 4A-GE -bellhousing bolted to Ford gearbox with homemade adapter...I think I still have adapter drawings somewhere in my garage... "Tämmösellä modernilla autolla, niin mun mielestä, ei tämmöstä kisaa voi ajaa. Tää käy kunnon päälle eikä riitä aivot tähän touhuun!" ""With a modern car like this, in my opinion, a competition like this can't be driven. It's too physical and your brains can't cope with this stuff" -Henri Toivonen 2.5.1986- http://www.youtube.com/watch?v=OwgB4Xs4LVQ |
12-27-2014, 01:30 AM
very nice part
01-02-2015, 06:13 PM
It´s not nice drawing, but it helps...thickness is about 22mm. T=Toyota (threaded holes) F= Ford (straight holes). Also on bellhousing must make some room for shifter shaft. "Tämmösellä modernilla autolla, niin mun mielestä, ei tämmöstä kisaa voi ajaa. Tää käy kunnon päälle eikä riitä aivot tähän touhuun!" ""With a modern car like this, in my opinion, a competition like this can't be driven. It's too physical and your brains can't cope with this stuff" -Henri Toivonen 2.5.1986- http://www.youtube.com/watch?v=OwgB4Xs4LVQ |
01-04-2015, 12:39 AM
Thanks S-K nice drawing, with all measurements.
I've receive the spigot bearing (for Ford type9) but it won't fit the Toyota crank. what solution did you use ? Thxs Phil Filh Save the RWD cars |
01-04-2015, 03:47 PM
(This post was last modified: 01-04-2015 03:47 PM by S.K..)
If I remember correct I use a 6902RS (28x15x7) bearing.
Toyota spigot bearing is 6001RS (28x12x8 ) and then measure Ford clutch axle diam. (I think it is a15mm). "Tämmösellä modernilla autolla, niin mun mielestä, ei tämmöstä kisaa voi ajaa. Tää käy kunnon päälle eikä riitä aivot tähän touhuun!" ""With a modern car like this, in my opinion, a competition like this can't be driven. It's too physical and your brains can't cope with this stuff" -Henri Toivonen 2.5.1986- http://www.youtube.com/watch?v=OwgB4Xs4LVQ |
01-04-2015, 08:02 PM
many thanks , your measurements looks correct. thanks for your answer , that will help me a lot .
Totta do you have same size for your spigot bearing? Phil Filh Save the RWD cars |
01-11-2015, 01:02 PM
Spigot bearing problem resolved . Thanks S.K.
Beginnning with Kouki gearbox member, to adapt with Type 9 gearbox mount . One day , one problem , I hope to get through before first rally ... Phil Filh Save the RWD cars |
Ford gearbox | totta Crolla | 0 | 1,089 |
02-15-2022 05:21 PM Last Post: totta Crolla |
4ac gearbox on 4age | hachirokkos | 2 | 5,286 |
05-24-2016 10:16 PM Last Post: banpei |
toyota a series engine....can a fwd corolla engine be used | 210 datsun guy | 5 | 7,644 |
7AGE to W58, cluth type? | slowboy2 | 3 | 5,110 |
05-25-2013 01:37 PM Last Post: slowboy2 |
Type of carbs to suit 4ag | kpretro84 | 23 | 21,357 |
02-09-2013 02:29 AM Last Post: bakonick |
