converting afm to map
08-16-2007, 02:10 PM
I would like to convert my blue top 4age from AFM to MAP.
What do I need? MAP sensor ECU? . . . . |
08-16-2007, 02:59 PM
As far as I know, if you have a Swiss afm hachi with 4agec (note the C), you won't gain much power with this type of conversion.
To obtain the same power that map sensored hachies have, you should use also the pistons from map sensored hachi. The pistons used in Swiss hachies are different (lower compression) that the ones used in map spec. 4age. Regards Andrej |
Converting Jap Spec wing mirrors to UK spec | chrisae86 | 5 | 1,686 |
04-12-2022 11:03 PM Last Post: chrisae86 |
AFM to Map Conversion | ps13michi | 3 | 2,414 |
Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP | mister86 | 12 | 9,660 |
extracted freedom ecu 16v ignition map | ditn | 7 | 8,130 |
Bluetop AFM with air filter | izanagi | 4 | 6,524 |
04-29-2016 07:29 PM Last Post: oldeskewltoy |
