catcams
12-16-2014, 10:49 PM
catcams | |||
12-17-2014, 12:25 AM
catcams
Great cams for standard gearbox!
12-17-2014, 07:05 AM
catcams
I struggle with the Dutch but are these the ...148s? If yes I'm interested.
AE86 ex-daily |
12-17-2014, 10:00 AM
catcams
Hi
Yes these are the 148,s |
12-17-2014, 10:40 AM
catcams
In welke setup had je ze zitten? Ik had in men vorige 4age hun setje voor standaard wagens zitten en was hier tevreden over. Indien ik deze ook kan draaien in een voor de rest originele motor heb ik interesse.
12-17-2014, 12:10 PM
catcams
Ik heb met deze cams niet gereden aangezien ik met turbo rij
12-17-2014, 01:28 PM
(This post was last modified: 12-17-2014 01:33 PM by Uzelac.)
catcams
These need heavy modification on valvetrain and careful engine build and valve timing. Duration is not so extreme but lift pretty much is.
Nevertheless, these will hit 160+hp easily without sacrificing lowend power. Suppose they could work on stock ECU with modifications in fuel delivery (injectors and fuel pressure) or piggyback addon. |
12-17-2014, 05:27 PM
catcams
Voorlopig niet hetgene wat ik wil doen, veel succes met de verkoop!
12-17-2014, 10:55 PM
catcams
Would you do 250€ delivered to Switzerland? If yes I'll take them
AE86 ex-daily |
12-17-2014, 11:11 PM
catcams
(12-17-2014 07:05 AM)Bean Bandit Wrote: I struggle with the Dutch but are these the ...148s? If yes I'm interested. be careful my friend... those cams are quite tall, either (more likely the intake) may hit the head Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
