a514mcl uk gt coupe rebuild
11-09-2009, 07:23 PM
tryed to paint the car myself and it didnt work out so i left the car away tonite to get painted as im too choosy and just cant do it to please myself. he says she will be ready fo lifting next friday. absolutly cant wait to get building at her. if shes back on time 2 weeks and she will be out.
11-09-2009, 07:24 PM
while the car is away for paint i thought this good time to rebuild the engine. goin to put in
new rings trd 0.8 steel gasket new oil pump new valve stem oil seals new crank seals new cam shaft seals new waterpump new crank bearings new con rod bearings arp head bolts lightened flywheel also: re seat the valves port and polish the head paint the engine aswell cams if i can sacrafise the money have most of the bits sitting here appart from the bearings started today by stripping the head and seating the valves have 8 exhaust valves as they were really bad im surprised the sealed at all. |
11-09-2009, 07:25 PM
my nearly new 4age.
decided to leave the cams for now to i get the engine run in for a few thousand miles or so. |
11-09-2009, 07:26 PM
getting there now the worst bit is over putting in the alarm and remote central locking system.
as im goin for the 84 grill i need the 2 inside headlamp brackets off a early spec car as the brackets are different for holding the early grill anyone have any? |
11-09-2009, 07:27 PM
been a bit slow there for a while as couldnt get near it. engine bay isnt far away now and bottom is near done aswell. while slow work making sure everything is perfect tight and all to stop rattles and not have to work at it again.
11-09-2009, 07:28 PM
got inside all waxoiled now so can go about fiting the rest of the interior now should look 100times better when interior is all in
11-09-2009, 07:29 PM
just a wee pictue of the toyota badge off the starlet. made 2 wee brackets to fit the early grill sits nice and neat now.
also the boot spoiler fitted what a job the brackets were all broke off it so made and plastic welded on new ones sealed the holes before i fitted it to stop water leaking and waxoyled the part if the boot under the spoiler as common to rust under it. |
should be finished next week hopefully, need the measurement from the grease nipple on the bottom of the front struts back to the axel mount to get the front wheels in the correct place please.
11-09-2009, 09:15 PM
Nice work there mate!
Scottish Trueno rebuild - Nürburgring with pics! | kazi | 77 | 164,127 |
11-25-2018 11:42 PM Last Post: kazi |
Patrick's rebuild topic | PatrickAE86 | 13 | 18,142 |
11-22-2017 05:49 PM Last Post: The Doctor |
DidiDex 1984 Levin coupe rebuild | DidiDex | 1 | 4,925 |
08-13-2015 03:22 PM Last Post: DidiDex |
Ae86 from Poland. Complete body rebuild | Doktor | 9 | 13,212 |
09-07-2013 11:07 PM Last Post: Doktor |
my slowly 1983 AE86 drift rebuild/ 1979 KE35 recovery | fax0815 | 68 | 103,237 |
11-12-2012 12:02 AM Last Post: fax0815 |
