ZDoman's projects - Hungary
12-11-2006, 11:23 PM
Post: #41
I took a look around my workshop. found some metal parts and welded an engine stand of them
and then I started to part the engine (4.2.2006) The intake manifold also had the coal-tar?/coat: |
12-11-2006, 11:41 PM
Post: #42
5.2.2005
oil squirter Piston and cylinder seemt good at this point I didn't know why had compression lost from the engine But the conrod bearings were worn. |
12-11-2006, 11:42 PM
Post: #43
Nice project mate, keep them coming
12-11-2006, 11:59 PM
Post: #44
Maybe this was the problem with the compression: Some coal was on the exhaust valve seats. But on all of the 8 valves so I don't know why just the cyl 2-3 had comp loss... :roll: I had a big trouble with the crank timing pulley, I wasn't able to pull it down. Finally I drilled a hole and broke it down... |
12-12-2006, 12:20 AM
Post: #45
I've sent the main parts to hot leaching/lixiviation bath
results were (pictures took on 7.2.2006) |
12-12-2006, 12:39 AM
Post: #46
The exhaust valves had some kind of coat. It was very hard on the valves I tried some kind of chemicals but no one made anyting. finally I removed them with Flex (angle grinder?) and steel brush...
So here I started some head porting. I just wanted to remove the big materials that 100% not needed and are in the way of the air. Nothing serious... The "tools" The base again on the intake side: First steps: |
12-12-2006, 12:44 AM
Post: #47
First step on the exhaust side:
second step from the combustion chamber side: |
12-12-2006, 12:50 AM
Post: #48
Mates
please tell me if you don't want so much pictures. I can take in only before & after pictures also... |
12-12-2006, 11:25 AM
Post: #49
Noooo, we want article too !
12-12-2006, 01:41 PM
Post: #50
Ofcourse we want to see more!
One hell of a topic already. > Hehe... I see you're hosting the images yourself. You can also attach them to the posts if you want to. But its your bandwidth. 1982 - TA60 Carina 4dr sedan - fun cruiser 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
ZaX's new projects | ZaX | 6 | 1,869 |
01-21-2023 07:23 PM Last Post: ZaX |
My Friend's Projects Started. | ToyotaTs | 72 | 51,557 |
01-19-2010 08:24 PM Last Post: oldskull |
Drift project from Hungary | AE86_Z | 66 | 87,951 |
12-14-2008 12:37 PM Last Post: AE86_Z |
Foto from ROTACHI projects 2009 | jardapek | 3 | 5,428 |
11-17-2008 11:02 PM Last Post: jardapek |
Projects section rules | banpei | 2 | 37,743 |
02-18-2005 11:24 AM Last Post: banpei |
