Windscreen
10-16-2022, 02:13 PM
Windscreen
That's the one I (and some others here) also intend to go for. Just not too sold on the greenish tint.
If you have any pictures that might be helpful please share. FABRICA MI DIEM, PVNC! |
10-16-2022, 07:07 PM
(This post was last modified: 10-16-2022 07:09 PM by totta Crolla.)
Windscreen
I'll try to load a picture.
To be honest l have not noticed any tint at all. Check the size before you order one. An analogue brain in a digital World |
10-17-2022, 08:28 AM
Windscreen
(10-16-2022 07:07 PM)totta Crolla Wrote: I'll try to load a picture. I have nothing left to check against. Anyone happen to know if you can measure the required windscreen height from the 2 bottom tabs that hold the window in position? FABRICA MI DIEM, PVNC! |
10-17-2022, 09:29 AM
(This post was last modified: 10-17-2022 09:35 AM by totta Crolla.)
Windscreen
You can, yes.
One screen is 735mm the other 760mm The heated type is 735mm In reality they should both fit, it is the scuttle panel that is different. I believe the U.K spec. (and maybe some others) have a deeper scuttle. The scuttle panel on my U.K car is 100mm deep. An analogue brain in a digital World |
10-17-2022, 05:27 PM
(This post was last modified: 10-17-2022 05:28 PM by The Doctor.)
Windscreen
I thought I saw in a recent juicebox video that the Japanese ones have the bigger screen. There was an irish guy who had loads of them and he said something like that.
10-18-2022, 10:08 PM
Windscreen
(10-17-2022 05:27 PM)The Doctor Wrote: I thought I saw in a recent juicebox video that the Japanese ones have the bigger screen. There was an irish guy who had loads of them and he said something like that.Yes that's correct. That's also why R.ave had issue with his window moulding as it was meant for the Japanese market. The scuttle panel is indeed different on the export models. It might also explain why the European and USDM cars have rust issues right below the windscreen as it isn't protected by a windscreen anymore and water can creep in. Then the rust destroys your windscreen from underneath! 1982 - TA60 Carina 4dr sedan - fun cruiser 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
Replacing Top Windscreen Moulding | chrisae86 | 2 | 1,525 |
