Which new bearings for ae101 4AGZE crankshaft&connecting
10-29-2013, 01:48 PM
Im currently rebuilding my ae101 4agze and i want to use new oem bearings for crankshaft & connecting rod
Im a bit confused to which mark i need to use Im thinking crankshaft MARK 3 11701-16010-03 connecting rod MARK 1 13041-16071-01 is this correct? 11711 BEARING, CRANKSHAFT 11701-16010-01 MARK 1 5 $18.56 11701-16010-02 MARK 2 5 $18.56 11701-16010-03 MARK 3 5 $18.56 11701-16010-04 MARK 4 5 $18.56 11701-16010-05 MARK 5 13041 BEARING, CONNECTING ROD 13041-16071-01 MARK 1 4 $14.87 13041-16071-02 MARK 2 4 $14.87 13041-16071-03 MARK 3 |
10-29-2013, 03:02 PM
You have to actually measure all the gap's... Follow the manual!
10-30-2013, 01:03 AM
If using genuine bearings, have a look at your crank, conrod and block markings, there will be numbers stamped into it.
for example if you doing a main bearing there will be a number on the crank and one on the block, and they will match up to a bearing size in the chart. All descibed in the manual. I´d still plastigauge them anyway. 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
10-31-2013, 06:04 PM
ok thanks for the help
Crankshaft stamping | Blaze0010 | 4 | 199 |
Yesterday 06:41 PM Last Post: oldeskewltoy |
20v BT - which oil pump? | Mylesmck | 4 | 2,010 |
Question on Rod Bearings | mister86 | 3 | 3,538 |
03-19-2020 03:46 AM Last Post: oldeskewltoy |
Emergency help find store with bearings france | Allexz | 5 | 4,146 |
09-12-2019 03:24 PM Last Post: Allexz |
AE101 4AGZE workshop manual | bozu | 1 | 6,491 |
04-04-2017 10:52 PM Last Post: hachirokkos |
