Tutorial : Megasquirting an European (MAP) AE86 (4age)
07-09-2013, 12:53 PM
Post: #61
You could add some advance while reaching some optimal cooling set point and/ or open the idle valve more. Keep an eye in AFR values because more advance or air will burn more lean.
IAT/CLT Related Ignition Warm up mode pack Wrote:So i have my car running ITB's the way gon explained. |
07-15-2013, 05:52 PM
Post: #62
Solved!
01-09-2014, 12:10 PM
Post: #63
Hi everyone!
Anyone with ignition tables for a stock engine and/or tuned engine? 16V Thanks |
01-09-2014, 08:29 PM
Post: #64
check on diyautotune.com - there's an msq available for download that comes with the mspnp
AE86 ex-daily |
01-09-2014, 08:33 PM
Post: #65
But the ignition map is not tuned for the 4AGE.
It has the basic setup to start the engine, but not a ignition map tuned in dyno. |
01-09-2014, 08:36 PM
Post: #66
pack Wrote:But the ignition map is not tuned for the 4AGE. every engine is different so there is no perfect map that anyone can send you. It should be good enough to get you started though. Also I think it was made on a dyno as they took it from their own MR2 build, before they went turbo. AE86 ex-daily |
01-09-2014, 11:12 PM
Post: #67
I have mine set up running with no problems.... But wanted to make sure the ignition timings are correct or am i using values that are restricting my engine...
01-09-2014, 11:23 PM
Post: #68
pack Wrote:I have mine set up running with no problems.... But wanted to make sure the ignition timings are correct or am i using values that are restricting my engine... Unfortunately only a dyno will tell you that, there's no shortcut around it. Save up, find a good deal and have it checked. AE86 ex-daily |
AFM to Map Conversion | ps13michi | 3 | 2,414 |
Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP | mister86 | 12 | 9,660 |
European/UK vs Japanese Levin "Glass Grill" | mad.matt | 3 | 4,800 |
10-20-2017 02:47 PM Last Post: mad.matt |
extracted freedom ecu 16v ignition map | ditn | 7 | 8,130 |
smallport question AFM or MAP? | fax0815 | 5 | 7,620 |
05-17-2014 05:07 AM Last Post: jondee86 |
