Tutorial : Megasquirting an European (MAP) AE86 (4age)
03-30-2009, 05:07 PM
Post: #41
fuel + spark maps with 288/272 please.
What cam timing for 288/272? Also can you psotdyno curve with AFR when finished? http://www.skynet.ie/~eireae86 |
03-30-2009, 07:30 PM
Post: #42
irishtwincam Wrote:24+4 should cause problems? On this setup megasquirt is used in MSnS mode . Only the 4 tooth wheel is used. The shield of the wire is not very important since the VR sensor wire is about 25cm long only. After that it arrives to the MAF ignitor where it is converted to digital. After it is in digital mode the shield is not very important. |
03-31-2009, 10:13 AM
Post: #43
Your using the stock igniter to convert the Sin wave into a digital signal
Interesting! http://www.skynet.ie/~eireae86 |
03-31-2009, 03:23 PM
Post: #44
yes ..... the MAF one ....
it says on the Tutorial .... stock stuff works best ....... |
04-01-2009, 11:59 PM
Post: #45
Er, spark timing please pretty pleae
04-23-2009, 09:06 AM
Post: #46
Hi Guys!
Finally my 4A-GE is working very nice with the MegaSquirt V2.2. Last weekend I passed the Hungarian Drift Association PRO class license with my AE86. Smtg like this : Regards, Z http://ae86.blog.hu - closed 2006 Toyota Corolla Verso 2.2 D4-D 1992 JDM Nissan Silvia PS13 RB26DETT powered |
04-27-2009, 04:02 PM
Post: #47
Gon, AE86_z,
Did you use 20v TPS? How do you wired it to the harness? I have mine this ways, but don't work [code:1:0523451c01]tps side > loom side brown > yellow Blue > red Red > Blue Yellow > brown[/code:1:0523451c01] I get FLOOD CLEAR in megatune and calibration process give same value on min/max fields. regards |
04-27-2009, 07:24 PM
Post: #48
i did use the 20v tps cant remeber how i wired it.
try diferent ways , you wont burn it |
04-28-2009, 08:51 AM
Post: #49
isac Wrote:Gon, AE86_z, Hi, I have the AE101 TPS too. The wires are here: AE101 Throttle Position Sensor 1 Y TPS constant voltage supply TPS power supply terminal Throttle Position Sensor 2 R TPS wiper track signal ECU terminal ‘VTA’ Throttle Position Sensor 3 B TPS idle position microswitch ECU terminal ‘IDL’ Throttle Position Sensor 4 BR TPS sensor earth ECU ‘E2’ sensor ground terminal. AE86 Throttle Position Sensor 1 B VCc TPS power supply terminal Throttle Position Sensor 2 R VTA ECU terminal ‘VTA’ Throttle Position Sensor 3 B IDL ECU terminal ‘IDL’ Throttle Position Sensor 4 BR E2 ECU ‘E2’ sensor ground terminal. Y=Yellow B=Blue R=Red BR=Brown Regards, Z http://ae86.blog.hu - closed 2006 Toyota Corolla Verso 2.2 D4-D 1992 JDM Nissan Silvia PS13 RB26DETT powered |
04-28-2009, 08:28 PM
Post: #50
Thanks! Everything works!
AFM to Map Conversion | ps13michi | 3 | 2,421 |
Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP | mister86 | 12 | 9,666 |
European/UK vs Japanese Levin "Glass Grill" | mad.matt | 3 | 4,800 |
10-20-2017 02:47 PM Last Post: mad.matt |
extracted freedom ecu 16v ignition map | ditn | 7 | 8,136 |
smallport question AFM or MAP? | fax0815 | 5 | 7,622 |
05-17-2014 05:07 AM Last Post: jondee86 |
