Testing AE86 on gravel
11-22-2012, 09:42 AM
Dino86 Wrote:Hey Zax,
nice video and respect for the camera-man Huh Respect!
Do you have rear swaybar connected on this setup, What do you use in the front?
Thanks
Hi Dino.
thank you. camera man has balls.
I have aftermarket rear sway bar. I tried the car without it and I did not like the feeling. Car would first roll then turn in to the corner, so I decided to put it back. I also heard rumors that people remove rear sway bar on live axle, but it did not work for me.
Setup of the car:
Sprigs: stock all around. I would like higher and stiffer in the back because car is compressed under acceleration.
Shocks: Yellow koni all around, set to medium soft.
Swaybar: front stock, rear ARC aftermarket (stiffer)
[Image: AEU86 AE86 - Testing AE86 on gravel]
11-24-2012, 07:33 PM
Thumbs up!
11-26-2012, 09:59 AM
And yes, we continued.
11-26-2012, 10:18 AM
Yikes, how did that happen?
11-26-2012, 04:41 PM
Steering hub nut got loose from shaking on gravel. Tooths on steerting shaft got worn. We lost "steering", you can see on the video that I turn left but car doesn't turn.
11-26-2012, 04:49 PM
After crash
  AE82 racecar engine testing firehawk 1 3,375 01-01-2006 11:53 PM
Last Post: firehawk
