TRC issue beams into ae86
10-06-2009, 07:03 PM
Hi guys, my name is jorge and I´m from Costa Rica Central America. I´m on the way to end my project which is a turbo black top beams into my AE86 for drifting. I have the stock computer and and greedy turbo kit. Have a few questions about the traction control wiring and ecu....
1-What you do with the traction control, do you use it? 2-If not, how you overcome this?, I found in the traction control wiring there´s a lot of ABS wiring also, so if I ended cutting those....it would affect the engine response/performance? 3-I have the possibility to use an AEM stand alone....could I get rid of that traction control unit/ecu? 4-Could I change the intake plenum for another one that didn´t utilize the traction control unit? Thanks A LOT for the help.... |
10-07-2009, 06:20 AM
When you say black top beams I assume you mean a 3S engine. I have no experience with these, but if you do use a standalone computer you will be able to remove all traction control functions.
If the traction control unit on the throttle body is non functional there shouldn't be a problem with leaving it, unless it causes issues with normal throttle/airflow operations. |
PWR light issue and no brake fluid after winter storage | magpie | 10 | 1,431 |
Fuel pump issue | DJexor | 11 | 3,614 |
Can you seperate trueno kouki bumper lights into zenki bumper lights? | gh0st | 17 | 5,905 |
12-19-2021 11:58 PM Last Post: gh0st |
Clutch Issue | Deaty | 8 | 3,474 |
04-09-2021 10:26 PM Last Post: Nakilad |
5th gear issue | r.ave | 1 | 2,189 |
03-14-2021 08:52 PM Last Post: Ivan141 |
