Steering shaft issue
11-15-2018, 07:42 PM
You can drill a small hole in the thick side of the bush and use a grub screw to hold the insert.
11-16-2018, 06:24 PM
(This post was last modified: 11-16-2018 07:28 PM by Ryo.)
The idea is good but i doubt it will withstand the drilling those bushings seems fragile i already tested i tried to melt one broken in order to weld another as i have 3 shafts but none is complete the other two i dismantled few years back. Yes stupid i know that i figured now that this part should be not dismantled. Looking more on the bushing place on the shaft you can notice it its like U shaped i think if they factory sealed this two points they used liquid like silon. As the material was sticking outsie the holes on the main shaft where they a are bind together the holes are 2mm in diameter only.
85' AE86 GT coupe lifetime project since 2005 |
11-16-2018, 11:23 PM
When you assemble the hollow shaft and the solid shaft together,
does not the nylon ring stay in the groove even if it is broken ? If the nylon ring stays in the groove (held/trapped in position between the two shafts) then it should work just the same... hmm ? Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
11-17-2018, 01:22 PM
(This post was last modified: 11-17-2018 01:23 PM by totta Crolla.)
(11-16-2018 11:23 PM)jondee86 Wrote: When you assemble the hollow shaft and the solid shaft together,I guess the question is whether the bushes transfer any of the force between the 2 shafts and would you feel any slack in the column when driving ? I would say not, I would say the bushes are there to ensure the column could collapse even if it became corroded, something that you eluded to earlier. ![]() An analogue brain in a digital World |
11-17-2018, 04:08 PM
(This post was last modified: 11-17-2018 04:09 PM by Ryo.)
What about polyamide hot melt sticks i can use a glue gun and use the holes to fill it in so it will be like factory made. I am still not sure what type of sticks to use as there are many on market with different properties for the glue gun so they have the properties of original but i am sure they used the same holes and the very same application when they put it together i photoed in detail where you can see it. It was clearly not solid form before.
11-19-2018, 09:52 AM
That looks like it was cast in place to me indeed. In that case, try getting your hands on some ABS or Nylon 3dprinting filament.. takes a lot of heat (200+C) to get it flowing but with care you could probably get it to work..
Fuel pump issue | DJexor | 11 | 2,026 |
Clutch Issue | Deaty | 8 | 2,615 |
04-09-2021 10:26 PM Last Post: Nakilad |
5th gear issue | r.ave | 1 | 1,797 |
03-14-2021 08:52 PM Last Post: Ivan141 |
Play between steering column and intermediate shaft after manual rack sonversion | DaLanZhu | 5 | 4,694 |
exhaust odor/idle MOT issue | Ryo | 7 | 5,614 |
