Start wont turn over after installing radio
09-17-2014, 10:28 AM
RE: Start wont turn over after installing radio
Sounds indeed like a bad battery (or alternator not charging a lot) or a bad ground connection.
The 4age starter is prone to not start with suboptimal batteries. Use a multimeter to check the voltage on your battery (should be 12.2 volts) and start the engine (jump start) and check the voltage again and it should be above 13 volts for a normal charge (around 2000rpm).
If the alternator is to blame the voltage should be below 13 volts when the engine runs, however if this is normal and the battery also has a good voltage you may should check the main ground connection.
[Image: AEU86 AE86 - RE: Start wont turn over af...ling radio]
Messages In This Thread
RE: Start wont turn over after installing radio - banpei - 09-17-2014 10:28 AM
  PWR light issue and no brake fluid after winter storage magpie 10 336 05-25-2023 08:09 AM
  Warm start problem DJexor 5 696 03-09-2023 10:15 AM
  20 Valve Blacktop smoking after engine flush - why? RolanTHUNDER 2 374 11-30-2022 12:09 PM
Last Post: RolanTHUNDER
  Play between steering column and intermediate shaft after manual rack sonversion DaLanZhu 5 4,867 07-31-2019 11:28 AM
  Weak spark, doesn’t start. AlexFourTwenty 4 11,057 12-12-2017 03:35 AM
Last Post: AlexFourTwenty
