Settings for APEXi SAFC???
04-27-2005, 11:29 PM
alimonos Wrote:Any suggestions not to make the engine "WAY too lean" as Denmark said?
Thumbs up!
Dont mess with the settings, plain and simple. :wink:
If you dont want to make it to lean, then dont turn the fuelmix down. But a very good idea is to buy and mount a lambda wideband sensor and the little box that shows the o2 level... Then youre sure not to make it to lean.
But again, i would really advise you not to fiddle with it too much. Tune your engine up with the parts you want, and then "polish" with the SAFC...
04-27-2005, 11:48 PM
OK my friends i got the point! :wink:
Thanks a lot again!!! Respect!
I'll start looking for some sharper cams and "nice" headers now...
Any "good-priced" suggestions? :wink:
04-28-2005, 07:32 AM
alimonos Wrote:OK my friends i got the point! :wink:
i've ordered some OBX-Racing headers in the usa.. for 185,- dollar.
Toyota Starlet 1994
Mitsubishi Space wagon 2.4 1999
ex Ae86 owner
04-28-2005, 09:11 AM
alimonos, when you buy the O2 sensor - choose the wideband one :-)
The narrowband will work too but it has different A/F curve and is hard (impossible) to use it for tunning.
About the headers - when I finish my "experiment" with turbo ones, I will try 4-1 TRD copy for NA :-) Maybe this weekend - who knows...
PS: Found link related to OBX - they seems to be TRD copies too.
http://forums.club4ag.com/topic.asp?TOPIC_ID=105150
04-28-2005, 10:10 AM
Alimonos I think you 've started from the end...
[Image: AEU86 AE86 - Settings for APEXi SAFC???] http://www.jdmbits.com
04-29-2005, 02:15 AM
@ nmwisima: Who knows??? Tongue
@ jammie: waiting for pics and prices... :wink:
@ Andre86: already seen them... Cool
04-29-2005, 10:54 AM
The Map sensored engine should be able to adjust for small changes in VE just fine. Headers etc are all wel within its possibilities, only when you start messing about with cams and camtimingwheels do you really start pushing things.
Tuning a stock engine with an AFC is a complete waste of the time and will hurt more then it does good.
06-09-2005, 10:26 PM
Need some help here guys... Dumb question
Using the APEXi manual can anybody tell me what type of ECU is mine? According to the manual it is a T1-c but i can't find in the 18p socket of the ECU the Presure Signal cable ... there isn't one there in mineDumb question
Any help?
06-09-2005, 11:11 PM
Well, from here i can clearly see the pressure signal in the t1-c ECU....? So i dont quite understand your problem...?
BTW, i used the diagram for Mr2, cause the manual says that theres no throttle signal in AE86.. And thats a lie :wink:
06-09-2005, 11:14 PM
Are you sure, that your engine is an mapped one? If you have AFM, its probably not the same diagram you should use.
  Torque settings kazi 4 5,422 03-28-2017 12:15 AM
Last Post: kazi
  What do you guys think of the APEXi SAFC-II system? heshan 2 3,266 02-28-2009 10:32 PM
Last Post: heshan
  Settings for HKS 256 cams on stock engine Bean 7 7,370 03-16-2008 10:56 AM
  How to improove oem WHEEL ALIGNMENT settings (toe&caster Apolan 13 11,110 03-12-2008 02:58 PM
Last Post: Roku_trueno
  Apexi Power FC Thor W 3 4,437 09-29-2007 12:42 AM
Last Post: SYM
