06-17-2010, 08:14 PM
Post: #321
Ok, for bigger power flex might be an issue. About not trusting crank scrapers: some OEM manufacturers build them into their engines from factory. They dont really come that close to the crank. That's why those Ishihara-Johnson fellows sell the teflon inserts which are meant to come into very close contact.
I have a feeling your oilpan will end up plenty expensive. The only way to get it much stiffer without putting a one-piece item in there is to use some kind of thick flange and weld the rest onto that. Will be heavy if made from steel, and expensive if made of aluminium. FABRICA MI DIEM, PVNC! |
06-18-2010, 03:54 PM
Post: #322
if you a little handy with a mig/tig welder then i think its not so expensive.
my cousin made also a bigger oilpan.You just have to make "schotten"(dono the english word for that) in the oilpan like in a fueltruck to avoid problems in corners daily driver avensis 2.0 d4d and Yaris 1.0 weekend driver 1985 AE86 |
06-18-2010, 06:38 PM
Post: #323
The making it bigger part is something any moron can do (not referring to your cousin BTW ). But making it strong enough to resist flexing of the engine is a different thing altogether.
06-18-2010, 08:18 PM
Post: #324
He has builded the same model of pan as in the pic.He is driving rallycross with it for years and never had any "flexing"? problems with it
06-18-2010, 09:21 PM
Post: #325
Had to think about this topic when I watched this vid today:
Sludge in teh oilpan! 1982 - TA60 Carina 4dr sedan - fun cruiser 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
06-18-2010, 09:57 PM
Post: #326
@Roger:
Even though an engine seems pretty solid, at high rpm the block itself is rumored to be prone to flexing, causing various problems. see: http://www.motoiq.com/MagazineArticles/t...a-4AG.aspx FABRICA MI DIEM, PVNC! |
06-29-2010, 10:34 PM
Post: #327
Well still working on the engine. Now with a high RPM tool.
Going to try and find some 200+ sanding grounds for my machine to super smooth it. Though this surface is already a million times better than it originally is. I actually have no clue if this mod is noticeable but it should increase cooling and oil flow trough the engine. So that would suffice for me. Also seems that the amount of shit that is originally on the block wall can come off gradually and damage bearings etc. Also I send a mail to a fabrication company which does mods on 4age's for kit cars. Hoping to see if I can design and build a custom oil pan with him. Any one ever tried making the cam covers together ? Also to strengthen the engine. Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
06-29-2010, 10:42 PM
Post: #328
if I remember correct the atlantic cam covers are onepiece items... but guess they would be kinda hard to get to without loads of $$$
AE86 ex-daily |
06-30-2010, 05:04 PM
Post: #329
Why constructing a new oilpan if you could just improve the crankcaps:
07-02-2010, 12:15 PM
Post: #330
MartinS Wrote:Why constructing a new oilpan if you could just improve the crankcaps: Looks nice. where can you buy it and what does it cost? But I am wondering what will happen with all hte oil that comes down the center channel. If that will be tossed back against the crank it will result into power loss due to drag? Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
Trueno Hatch and Levin Coupe - Repair, replace, pray xD | TomRich | 13 | 13,082 |
@dodo@ Levin Coupe, renovation and tuning (56k think twice) | @dodo@ | 165 | 148,610 |
Aram's 3SGE Beams Levin Coupe | robokill | 665 | 687,840 |
8a9 blue gt coupe | McGlinchey | 8 | 8,948 |
06-22-2016 02:19 PM Last Post: McGlinchey |
Matt's "Drives as fast as it's Towed" 85 Levin Coupe | mad.matt | 38 | 37,041 |
04-07-2016 12:15 PM Last Post: mad.matt |
