Realhachik
04-10-2010, 08:25 PM
Realhachik
this will be soon rear 4-links
owau no ka "I" |
04-19-2010, 05:39 AM
Realhachik
it've finally came back to the garage.
spray anti rust on the cage before painting and some more progress - installed hood pins and assemble front break lines. next weekend I'll paint the cage and start to assemble rest of the car. now it will be with stock 4a, but soon(I hope it will be soon :wink to be swapped with honda F20C engine, it's so expensive here need to keep money owau no ka "I" |
04-19-2010, 01:15 PM
Realhachik
the F20C is a very sough after engine which seems to have bumped up prices to ridiculous levels. but the engine is a perfect fit for the AE86.
oh just to say those wheels are super eye candy absolute monsters |
04-19-2010, 06:36 PM
Realhachik
Hey man! Nice project!
From what dealer in US did you order those rims? And what size tires are you using? |
04-19-2010, 09:05 PM
Realhachik
thnx guys.
wheels were ordered directly from aerorace by one friend in US tyres are 215/50 bridgestone MY01 owau no ka "I" |
04-20-2010, 04:24 AM
Realhachik
boo50 Wrote:thnx guys. Are you sure the rear rims are also -11 offset? Sounds like too little for a 10" rim.. |
04-20-2010, 05:24 AM
Realhachik
I'm sure
it's really tight to fit, just 2mm from wheel to lower shock mount point. if you're gonna such wide wheels I'm recommend to got with offset -10 and less (-20 / -30 ....) always like white engine bays ) my small dream come true. and roll cage as well owau no ka "I" |
05-24-2010, 05:15 PM
Realhachik
take a vacation for a week at work to finish car.
almost finished. need only make shifter and car can move. Compbrake pedal set is really not bolt-on (can't compare with Tilton) I've a lot of cut, drill and adjust everything, even stroke on cylinders because they too long. but finally everything is working and full throttle adjusted ) owau no ka "I" |
05-30-2010, 07:22 AM
Realhachik
yesterday make a shifter
can't catch a metal-turner, so make an easy solution owau no ka "I" |
05-30-2010, 03:12 PM
Realhachik
Great work!
4AGE 16v on ITB's |
