Racecar: TRD USA built ITA AE86
10-10-2017, 08:16 PM
very cool ae86 i love those old vintage racing ae86's.
Definitely will be following this thread. |
10-10-2017, 09:03 PM
Wow, that's indeed a challenge to replace the cluster!
I fitted Euro MR2 lenses on my JDM bumper, but that's because regulations in Europe required it. I think in your case you need to have it either as one shared amber light (USDM), or the two separate amber lights (JDM). Personally I like the zenki one the best... 1982 - TA60 Carina 4dr sedan - fun cruiser 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
10-11-2017, 12:44 PM
Try salad oil on the residue should work magic
10-11-2017, 08:45 PM
(This post was last modified: 10-11-2017 08:47 PM by oldeskewltoy.)
(10-10-2017 02:58 PM)Bean Wrote: I like the Zenki type, suites it well. WD-40 + a soft Scotch Brite pad + time + hot soapy water = .......... front lamps finished... rear lamps left to do....... I tried peanut butter, WD-40, and olive oil........ the peanut butter and olive oil (didn't have any "salad oil") did little or nothing. The hot water was key. More to come..... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
10-19-2017, 12:44 AM
(10-09-2017 10:36 PM)oldeskewltoy Wrote: there is no engine fan, mechanical driven or electric, has made me a bit uncomfortable. David (previous owner) said it wasn't a problem, after all this is a race car, it is used on track........ key part to getting the fan in, and operational is the proper parts. Below is a coolant inlet for an AE82. This will bolt in as the stock one does, and is even pointing in the correct place. The original Toyota switch is grounded, and when hot it breaks the ground(opens) and the fan comes on. This works as a safety as well, if the switch breaks, the fan stays on. For Racecar I'm using a Honda switch, that will be open, and close @ temp (reverse of Toyota switch). This makes wiring the fan a bit simpler since the Honda switch is more conventional in operation. BUT... the sensor doesn't quite fit. The hole for the probe is too narrow, and the threads aren't deep enough. So a few mods.... and the Honda switch becomes right at home.... with just enough of the sensor in the coolant to operate, yet not so far in that it seriously disrupts flow more to come..... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
10-19-2017, 07:44 AM
Wow. What a machine. I will follow this build. The cage has a diagonal cross member right? Is the shotgun seat even usable?
10-19-2017, 06:18 PM
(This post was last modified: 10-19-2017 06:23 PM by oldeskewltoy.)
(10-19-2017 07:44 AM)Hama86 Wrote: Wow. What a machine. I will follow this build. The cage has a diagonal cross member right? Is the shotgun seat even usable? No shotgun seat anymore...... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
10-20-2017, 11:03 AM
better design rollcage.
In the old days it would have shitty aluminium rollcage. |
10-23-2017, 01:54 PM
dayum. What a car. I can also see impact absorbers on the driver side? (wavy sheet metal)
01-16-2018, 03:56 AM
oldeskewltoy Wrote:current livery... almost there........ still need to replicate a few pieces... but she is what she was...... more to come.... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
(Catching up) OST-086 MM: Built for Mario | oldeskewltoy | 2 | 1,795 |
ae86 racecar with beams engine | bakonick | 145 | 151,813 |
07-02-2022 06:37 PM Last Post: bakonick |
ae86 Trueno f20c Built to be driven not polished | Martynas | 45 | 51,645 |
05-29-2020 12:59 PM Last Post: decryphe |
S.K.s AE86 racecar | S.K. | 207 | 206,763 |
09-18-2016 11:39 AM Last Post: totta Crolla |
Built like an A-10 (Thunderbolt II aka Warthog) | assassin10000 | 32 | 43,946 |
03-20-2012 12:33 PM Last Post: assassin10000 |
