Project from Denmark
07-18-2017, 09:31 AM
Post: #71
I really hope so, with the amount of work I am putting in to it, and not to talk about the huge pile of money Angel
Got another update planed, so stay tuned for more boring rust work Love it!
Restoring my AE86, all the way... Going JDM style Big Grin
http://www.aeu86.org/viewtopic/ae86/p/150463#150463
07-18-2017, 09:28 PM
Post: #72
Time for some more work, this time I am working on the left rear side.
First I spent some time removing the old Rear quarter panel, took some extra time due to the old rust work I had done (solid welded it)
But of it came, took the outer piece of the inner fender of too... Tongue
[Image: AEU86 AE86 - Project from Denmark]
A while back, I found a brand new outer piece of the inner fender Hurray!
The rear pocket needs some work, in order to become hole again.
Got this cut from another car, its almost complete, and will make the fix much easier. Smile
Here I have cut out the rotten parts, and fitted the restored shell cut.
After a bit of welding and grinding, the rear pocket is complete again.
07-25-2017, 09:25 PM (This post was last modified: 07-25-2017 09:27 PM by Vaptor.)
Post: #73
A bit more rust work done Cool
Was not quite finished with the rear pocket, forgot all about this small piece, that needed some work.
After a bit work, it was ready to be put back on the car.
When I cleaned the inside of the car, I noticed some rust along the inner wheel house, so took of the reinforced plates to have closer look. And it was a pretty site Confused
After a good cleaning, I could see the parts that needed to be cut out, in order to remove all the bad metal.
Replaced the missing parts, with some fresh metal.
After some welding and grinding, the reinforcement plates where back on the car again.
Now there are no more rust, that hinders me from putting back some of the new body panels I have, can't wait Hurray!
08-01-2017, 04:22 AM (This post was last modified: 08-03-2017 05:18 PM by headrush.)
Post: #74
Well done man, that's an insane amount of work you've done there! I wish I had 1/1000th part of your skills!
Now you're entering the fun stage of putting your car back together Big Grin
08-23-2017, 11:13 PM
Post: #75
Finally time to fit some lager parts to the Shell Hurray!
I let the pictures speak for them self.
Great to see some real progress Cool
Next I need to fix two holes behind the rear seats, then change the sills before I finally can put the Rear quoter panels and roof back on.
Hope that by christmas it looks like a car again Angel
08-24-2017, 08:28 PM
Post: #76
Wow! Nice progress! It looks like your car is getting some structure back! Thumbs up!
08-24-2017, 08:46 PM
Post: #77
Yea. Finally it start to look like a car again.
08-30-2017, 08:44 PM
Post: #78
Excellent work, you must be very hand with a welder
