Project SE82 (3S-GE powered AE82)
11-21-2005, 06:11 PM
I have been wanting to do this (building a racecar out of an old corolla) for many years, but I always thouth it was for "those other guys". About a year ago I got to thinking.. Why couldn't I do this as well as anybody else? I only have one life, so why not live it now, right?
So... I'm not going to bore you with all the stories about the project that you are not interested in and I have forgotten half of. Instead I'll go right to the essentials. Origin: 1985 Toyota corolla 1.6 DX 4A-C powered front-wheel-drive granny transporter Engine: 2nd Generation 3SGE from a 1991 Celica GTi Suspension: Not really sure yet what the combination of corolla/celica parts I will use but the Celica parts will (probably) be from the generation previous to the engine donor because of the difference in availability (and price ). Although I am a bit curious about one of those DIY Coilover kits available on EBAY. Brakes: I will most certainly use a complete stock ST162 brake system. Using: -98 Camry 3.0 V6 Abusing : -85 Corolla 2.0 GTi |
11-21-2005, 06:41 PM
Yeah post pics and info! Sounds like a lot of fun
11-21-2005, 11:12 PM
Ofcourse it can be drifted!!! Full reverse drift! >
No, we actually had a discussion about this. It would be possible to start a FWD to drift, but not sustain the drift. But that is a too long discussion to start over here... Show us the pics!!!! [/list] 1982 - TA60 Carina 4dr sedan - fun cruiser 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
11-22-2005, 03:15 AM
(I have removed the question in the first post. One of you moderators can remove your answers if you like.)
Allrightythen I guess you want to see some pics. This is the poor excuse for an engine that was there before: The front and rear tranny mounts bolts almost right up to the S-53 tranny.. The front one needed to be moved a little bit to the right for the engine to point straight. The left and right mount couldn't be used at all since they weren't only in the wrong places. They were also too narrow. So I cut them off, along with the battery plate. The battery will be moved to the trunk anyway. Testfitted the new engine: The right engine mount. As you can see it wouldn't have fit at all. Really dirty tranny.. This mount needed to be moved a little bit forwards. Begun working on the left tranny mount. Cutting that 4mm steel plate with a 3mm cutting disc on the angle grinder is hard work: Also removed the tank because it needs to be converted to EFI.. As you all can see, there is still A LOT to be done.. Not as fun to work on it now as it was in the summer though.. Had about 7 degrees C in the garage today.. So what do you think? Should I keep posting pics? (retorical question ) Using: -98 Camry 3.0 V6 Abusing : -85 Corolla 2.0 GTi |
11-22-2005, 12:06 PM
keep posting this looks interesting
11-24-2005, 12:28 AM
yeh look interesting keep us updated
11-24-2005, 12:06 PM
Isn't that an AE80? The AE82 is a hatchback I guess!
Best regards |
11-24-2005, 01:42 PM
are you planning on turboing the 3s? would make a killer sleeper.
11-24-2005, 02:03 PM
yep man keep those pic and progress posted, really interested in seening how this goes!
11-24-2005, 05:31 PM
Apolan Wrote:are you planning on turboing the 3s? would make a killer sleeper. ~160hp and ~900kg will make it a sleeper anyway.. Plus, swedish laws make it impossible for me to get it legal if I turbo it. But you never know.. Using: -98 Camry 3.0 V6 Abusing : -85 Corolla 2.0 GTi |
NZ AE85 - soon to be BEAMS powered | Hachi Go | 46 | 68,856 |
06-24-2011 10:12 PM Last Post: [Walaki]D`Lair |
X-TURBO ae82 5dr, the daily badass | Lajoosh | 13 | 18,046 |
09-25-2010 09:24 PM Last Post: Lajoosh |
The MCNSPORT.com RE86 - Rotary Powered AE86.. | MCNSPORT.com | 19 | 26,860 |
10-08-2009 08:56 PM Last Post: MCNSPORT.com |
4AGE Powered 1972 MG Midget | byd1380 | 7 | 15,629 |
04-25-2009 04:12 PM Last Post: Garry Mckenzie |
Rotachi 13BT powered by Jarda [CZ] | SekiguchiUeno | 1 | 5,143 |
04-24-2008 10:17 PM Last Post: SekiguchiUeno |
