OST-064: Breathing on a 3 rib
02-01-2020, 02:02 AM
more to come..... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
02-03-2020, 06:45 PM
OST-064 "Cleaned"....
After getting it cleaned, I deburred the casting And then before porting, I had it "tumbled" so the head now looks new, no discoloration do to oils, carbon, or coolants. more to come...... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
02-04-2020, 09:30 PM
Indeed it looks very clean! How many Ks did it run?
1982 - TA60 Carina 4dr sedan - fun cruiser 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
02-06-2020, 10:57 PM
(02-04-2020 09:30 PM)banpei Wrote: Indeed it looks very clean! How many Ks did it run? Ks??? Kilometers? no idea, although I do know this head has been in storage for at least 10 years before got it...... Work begins.... One done... and a bit closer... more to come.... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
02-06-2020, 11:26 PM
Indeed Ks in kilometers. I know: I should have said Ms...
02-11-2020, 05:37 PM
(This post was last modified: 02-11-2020 05:40 PM by oldeskewltoy.)
oldeskewltoy Wrote: 2 down.... more to come......... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
02-12-2020, 05:53 PM
(This post was last modified: 02-12-2020 05:53 PM by oldeskewltoy.)
from another forum Wrote:what does "tumbling" the head consist of? Is it similar to tumbling bullet casings? Not sure (tumbling bullet casings...???) What "tumbling" means in this case is they have a large tool - it consists of a large cabinet, with a rotisserie that you strap the head too. The cabinet is closet, and it tumbles inside the cabinet. The media used is cast zinc shot. a bit further yesterday..... 3 down.... and an up close view inside on the exhaust side.... more to come..... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
02-15-2020, 04:42 AM
oldeskewltoy Wrote: 4 down.... more to come..... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
03-12-2020, 12:09 AM
and the internals.......
crank on right has wankered key groove in snout more to come..... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
03-19-2020, 02:30 AM
everything is back in my hands for final assembly....
head, with fresh valve job (machined .008")... along with assembled short block - those are Molnar Tech 40/20 H- beam rods Does anyone see the remnants of a problem in the deck??? It took a great deal of decking to get the block suitable to accept a metal gasket.... so much so that our deck is now .018" (piston above the deck!) The "fix", Cometic C4166-051, that should set the squish back to .033", or just a tick above .8mm....... More to come..... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
(Catching up) OST-086 MM: Built for Mario | oldeskewltoy | 2 | 1,851 |
OST-093: My, My, Mystery | oldeskewltoy | 10 | 3,137 |
(Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams | oldeskewltoy | 5 | 2,264 |
(Catching up...) OST-083: Salvage operation | oldeskewltoy | 2 | 1,522 |
(Catching up...) OST-082: Nope, never again... at least not without all the parts | oldeskewltoy | 0 | 1,233 |
