OST-050 - a VERY special build
10-05-2018, 09:40 PM
Post: #31
RE: OST-050 - a VERY special build
The assembled short block is back in my hands.....
![]() isn't it pretty..... with 10.0:1 piston fitted, and a fresh deck ![]() ![]() but "pretty" needs to go to the CORE....... (upper view = 1 & 4 @ TDC, lower view = 2 & 3 @ TDC) a fully balanced bottom end... not only pretty, but BETTER then OEM ![]() ![]() Can you find any(all?) of the new balancing?? and to go along with a balanced rotating assembly... more balance.... from the new OEM pulley to a new Toyota pressure plate, and yes even a Toda flywheel needed a tiny bit of balancing... ![]() ![]() more to come....... ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
OST-093: My, My, Mystery | oldeskewltoy | 6 | 283 |
08-01-2022 05:11 PM Last Post: oldeskewltoy |
(Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams | oldeskewltoy | 0 | 126 |
07-28-2022 01:18 AM Last Post: oldeskewltoy |
(Catching up...) OST-083: Salvage operation | oldeskewltoy | 2 | 198 |
(Catching up...) OST-082: Nope, never again... at least not without all the parts | oldeskewltoy | 0 | 175 |
(Catching up...) OST-081: STOP... do not touch if you don't know wtf you are doing | oldeskewltoy | 0 | 256 |
06-17-2022 09:07 PM Last Post: oldeskewltoy |
