OST-045: 5AGTE... again ;)
02-09-2018, 08:15 PM
(This post was last modified: 02-09-2018 08:16 PM by oldeskewltoy.)
(02-09-2018 02:11 PM)Dave W Wrote: Dan No dyno testing on this by me... and while I've heard of anti reversion, I've yet to see anything built into a 4AG head... and only a rare few built into headers from another forum Wrote:That's a lot of material in the one port :!: with a lot more to remove! 2 down... 2 to go more to come.... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
02-11-2018, 08:49 PM
Ready for her multi angle......
more to come...... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
02-22-2018, 07:25 PM
back from her multi angle....
02-25-2018, 12:42 AM
Chambers currently @ 37cc. Now to decide what the final volume is to be, and then machine the surface to size. This head has not been machined since it left Toyota. Once machined we can move on to assembly, and fitting the cams. more to come.... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
03-11-2018, 12:33 AM
another forum Wrote:Amazing work as always. How the heck do you get those shallow coolant passages around the chambers so clean? oldeskewltoy Wrote:One of the costs.... I have each head cleaned and pressure checked at a machine shop. In this case the head did come to me cleaned already, but I still had it checked for its pressure holding capability. another forum Wrote:The machine shop that does the work is seriously impressive then. I took two heads so far to two different machine shops and neither could get the coolant passages as spotless as this. Not all of the heads I work have this "pretty" of a finish from cleaning... BUT... all heads leaving are machined so that you can read in their reflection... OR more appropriate - fully ready for a metal head gasket! More to come........ Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
03-19-2018, 05:38 PM
ready for assembly.... with a pair of Cat camshafts
more to come......... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
03-27-2018, 08:12 PM
For shipping: With cam dummies in I can keep the shims I want in place without having the cams installed..... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
(Catching up) OST-086 MM: Built for Mario | oldeskewltoy | 2 | 1,843 |
OST-093: My, My, Mystery | oldeskewltoy | 10 | 3,117 |
(Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams | oldeskewltoy | 5 | 2,258 |
(Catching up...) OST-083: Salvage operation | oldeskewltoy | 2 | 1,512 |
(Catching up...) OST-082: Nope, never again... at least not without all the parts | oldeskewltoy | 0 | 1,225 |
