OST-045: 5AGTE... again ;)
01-18-2018, 12:46 AM
As arrived. The head has been cleaned, but I don't know if it has also be pressure tested, so I'll be sending it out, along with all the associated bits to get cleaned and pressure checked before I start work. The buckets and shims have seen better days... replacing them with good used units is far less costly then trying to salvage these More to come....... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
01-19-2018, 07:57 PM
work begins.... de-burring the casting......
more to come...... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
01-23-2018, 04:20 AM
working the first set of bowls and seats..... more to come....... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
01-25-2018, 02:03 AM
2 down.... 2 to go....
01-26-2018, 08:33 PM
Just about done on the intake side.........
more to come..... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
01-27-2018, 02:41 AM
next... the exhaust side.... more to come........ Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
02-01-2018, 12:05 AM
(This post was last modified: 02-01-2018 12:15 AM by oldeskewltoy.)
Chamber work has begun..... more to come....... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
02-05-2018, 10:51 PM
3 chambers down......
sometimes the right tool is the simplest.... working the chamber wall with 120 grit. more to come.... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
02-08-2018, 05:51 PM
Chambers done...... (for now)
work begins on the exhaust side.... one done... one under construction more to come...... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
02-09-2018, 02:11 PM
Dan
Have you send any dyno testing that would indicate that the 4AGE would see favorable power gains by incorporating anti-reversion step in the exhaust port - header. I've already increased the exhaust port by about 3mm, but was thinking about grinding out the header I.D. at the head attachment face. Dave W |
(Catching up) OST-086 MM: Built for Mario | oldeskewltoy | 2 | 1,858 |
OST-093: My, My, Mystery | oldeskewltoy | 10 | 3,160 |
(Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams | oldeskewltoy | 5 | 2,278 |
(Catching up...) OST-083: Salvage operation | oldeskewltoy | 2 | 1,536 |
(Catching up...) OST-082: Nope, never again... at least not without all the parts | oldeskewltoy | 0 | 1,237 |
