OST-015: The long and winding road.....
12-07-2011, 04:31 AM
owner OST-015 Wrote:At 01:33 AM 10/25/2010, you wrote: Fast Forward 13+ months....... OST-015 will be a ported smallport head. It will be mounted on top of a 7A. The builder will be using 4AGE high comp pistons. As of last report the builder is using Tri-Flow cams. The engine will be mounted in a 1989 MR2(AW11)..... and it will be using full emissions since the car, engine, and owner all reside in California. More to come..... when it arrives :eek: that should be tomorrow. Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
12-09-2011, 04:13 AM
oldeskewltoy Wrote:More to come..... when it arrives :eek: It did, and it was....... It did arrive, and it was tomorrow/yesterday @ about 5:30pm... That was why no post yesterday :eek: Nice, simple, clean box....... Hmmmm, once opened Whats this? A big block of styrofoam! Once the block of styrofoam is removed.... what should appear but a smallport head with 8 pairs of valves... :lol: The head has been mostly cleaned, there is still some carbon left in the exhaust ports, and some residual debris caught in the casting porting should proceed beginning tomorrow.....:thumbsup: more to come Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
12-09-2011, 04:30 AM
whooops... forgot :wink:
12-13-2011, 06:44 PM
Well got down to some work today....
Below are a pair of port comparison... exhaust 1st.... This was one of those tough to take photos... the ported one. I had to defuse about 25% of the light so that the photo would be clear. On the intake side.... More to come Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
12-14-2011, 11:37 PM
Very impressive!
1982 - TA60 Carina 4dr sedan - fun cruiser 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
12-15-2011, 12:06 AM
Nice
BTW. do you have any chart or dyno's, before and after ? All your work look impressive, even better is the fact that you share your knowledge and work. And since you are taking the different routes with different heads, it would be interesting to see what made the difference. |
12-15-2011, 03:27 AM
Uzelac Wrote:Nice Will a flow bench read out be sufficient? It use to cost me about $150 per chamber to get before, and after readings. $600 per head is VERY costly. I take what I've learned, and applied it to what I do from another forum Wrote:I'm curious what accommodations you've made for the 7A. I've made no unusual accomodations for 7A use. The client is using Supertech std size valves, I'm de-shrouding the chambers, and I'm re-tapering the exhaust ports to allow higher volume. I'm also "opening" up the top of the smallport intake port to expose the outer port walls/channel speaking about deshrouding the chambers, here are chambers #1(left), and #2(right) I've not only deshrouded the chamber, but I've deburred the chamber edge. To get a good idea, look at the chamber edge on the right hand side, chamber 2, note the left hand intake - now look at the edge of the chamber in that area... see the ragged edge. If you look around the left hand view, no such ragged edge Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
12-16-2011, 02:36 AM
It is what makes power :eek: at least in a 4AG head
exhaust port #2 seen on left in views above, is seen below .................................................... #2 exhaust port from untouched, to mostly finished, with a stop in the "roughed out" phase in the middle Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
12-16-2011, 05:18 PM
oldeskewltoy Wrote:Uzelac Wrote:Nice What have you done to this head? Is it smallport or bigport? Thanks |
12-17-2011, 03:37 AM
Uzelac Wrote:Is it smallport or bigport? bigport - what was done, was everything I do...... A somewhat familiar photo for one of my porting logs.... There is no special lighting... 2 exhaust ports down.... 2 to go. And accompanying it... 2 chambers down, 2 chambers to go... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
(Catching up) OST-086 MM: Built for Mario | oldeskewltoy | 2 | 1,840 |
OST-093: My, My, Mystery | oldeskewltoy | 10 | 3,107 |
(Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams | oldeskewltoy | 5 | 2,250 |
(Catching up...) OST-083: Salvage operation | oldeskewltoy | 2 | 1,502 |
(Catching up...) OST-082: Nope, never again... at least not without all the parts | oldeskewltoy | 0 | 1,219 |
